MBP Posted January 8, 2019 Share Posted January 8, 2019 Hello everyone, MANBEARPIG here, I’m new to the group, so hello! Anyway, I just got a 1999 leg sedan L, I’m told it’s a 2nd gen in the states so I apologize in advance, but I was wondering if you folks had any recommendations for a good reliable set of read struts? I wouldn’t mind if the car stanced higher in the rear, but I’m not looking to blow my load on anything aggressive. I just want something solid, good for the money, easy to instal, and good for a daily driver. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
AWDFTW Posted January 8, 2019 Share Posted January 8, 2019 Kyb. Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 9, 2019 Share Posted January 9, 2019 (edited) Unfortunately only crappy companies make quick struts for older legacys. The best route of replacement is to go with KYB Struts, which are about 65$ each. I would also replace the top hats as the bearing tend to wear out quickly. You usually don't have to replace the springs(unless rusty),boots,spring seat seal or bump stops. The only other sensible option is OEM but the price is hefty for a 20 year old car. People use Monroe but they tend to go out a lot quicker than KYB. I have about 30k miles on my KYBs and they still are hold up like new. Edited January 9, 2019 by RumbleRumble Link to comment Share on other sites More sharing options...
MBP Posted January 9, 2019 Author Share Posted January 9, 2019 Sounds to me like KYB is the way for me, thanks fellas Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 9, 2019 Share Posted January 9, 2019 (edited) Also don't buy cheap top mounts. I got 20$ ones and had this happen. The bearing is press fitted into the rubber mount and mine separated. Couldn't figure out the front end clunk until the strut fell out when changing the knuckle. Edited January 9, 2019 by RumbleRumble Link to comment Share on other sites More sharing options...
MBP Posted January 9, 2019 Author Share Posted January 9, 2019 Alright, so do you guys have a source you usually get parts from? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
AWDFTW Posted January 10, 2019 Share Posted January 10, 2019 I crosscheck Amazon, Rockauto, Ebay and go with the cheapest. Usually RA. Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 10, 2019 Share Posted January 10, 2019 Yeah eBay usually has the best prices. Sometimes it's easier to find parts on rock-auto then just google the part numbers. Link to comment Share on other sites More sharing options...
