ssbtech Posted January 7, 2019 Share Posted January 7, 2019 Here's an odd one that just cropped up - car has decided it wants to stall occasionally when stopped. Where do I start looking for a cause? :/ Link to comment Share on other sites More sharing options...
Notorious Posted January 7, 2019 Share Posted January 7, 2019 Inspect all vacuum and intake lines. First culprit would be the blue T fitting under the intercooler. https://legacygt.com/forums/showthread.php/2005-2006-lgt-colored-vacuum-routing-diagram-143225.html Link to comment Share on other sites More sharing options...
ssbtech Posted January 7, 2019 Author Share Posted January 7, 2019 Thanks. I'll add that when I pulled a learning view, my AF Learning was -0.9, 0.1, -3.00 and -2.6, all within acceptable ranges. I did pop the IC off last night and re-seated the TB hose. Link to comment Share on other sites More sharing options...
ssbtech Posted January 7, 2019 Author Share Posted January 7, 2019 No stalling this morning, but my commute is barely 15 minutes. Oh, any suggested parameters to log in RomRaider while out on a drive that may help narrow this down? Perhaps logging something like AFR and comparing that to throttle/RPM or something might bring a little insight into what's happening. Link to comment Share on other sites More sharing options...
