glynnaviation Posted January 7, 2019 Share Posted January 7, 2019 Front wheels vibrate when braking above 50 miles an hour. When I change down with the paddles and the weight comes on to the front wheels a lot of the vibration goes away. Not sure if it's the brakes or the front end or the shocks please advise Sent from my Pixel 2 using Tapatalk Link to comment Share on other sites More sharing options...
Dishwasher Posted January 7, 2019 Share Posted January 7, 2019 re-bed your brakes, if that doesn't work pop off the offending rotors (probably rears if you don't feel it in the steering wheel) run them up to O'Reilly's and have them resurface them for $25. Link to comment Share on other sites More sharing options...
Carmania24 Posted January 7, 2019 Share Posted January 7, 2019 ^ +1. Mine had really shot control arm bushings, after I replaced em, the vibrations during braking went away. But I have to also replace my rotors as they are getting bad. I recommend checking out the bushings, see if they may be going bad/are bad. Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 7, 2019 Share Posted January 7, 2019 Bad outer tie rod end and potentially LCA bushings Link to comment Share on other sites More sharing options...
