robertsm99 Posted January 4, 2019 Share Posted January 4, 2019 Recently, I haven't been able to roll down my right rear window, from my driver's side window controls. I thought the issue was with the window itself, and the motor. I just tried to use it from the window button on the door itself and it worked just fine. My Drivers side won't work. Is this a switch issue? Is it easy to replace, aside from taking the door apart? Or is it more complicated and I have to figure out the wiring to the window controls? I'm hoping it's a simple switch that wore out and is easy to replace. Anyone ever have this issue as well? Link to comment Share on other sites More sharing options...
15legacy1657616192 Posted January 4, 2019 Share Posted January 4, 2019 Lower the window using the button in the backseat and once the window is down, keep holding the button for 5 seconds. Then pull up on the button and hold for 5 seconds after the window closes. That was the fix for my drivers controls not working after installing a new battery- might work for this too. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
robertsm99 Posted January 6, 2019 Author Share Posted January 6, 2019 Thanks for the info, I did just put a new battery in not long ago, and not sure if it was acting up before the battery change or not. Link to comment Share on other sites More sharing options...
robertsm99 Posted January 10, 2019 Author Share Posted January 10, 2019 Well that actually worked. Not sure what that's about, but that fix worked. Thanks. Link to comment Share on other sites More sharing options...
