tmBH5 Posted January 4, 2019 Share Posted January 4, 2019 Hi.. i just bought this car not long ago.... basically is a nice car,... lately i have issues with my idling problem. i have change a air mass sensor coils n plugs throttle body iavc the idling problems only during whenever i stoppedat traffic light or sometimes when its just standstills Link to comment Share on other sites More sharing options...
xrayspecs Posted January 4, 2019 Share Posted January 4, 2019 Check the filters (air & fuel) also could be a vacuum leak. Link to comment Share on other sites More sharing options...
giiyanman Posted January 4, 2019 Share Posted January 4, 2019 (edited) By idling problem, you mean you feel engine misfires, CEL comes on intermittently and you can feel the whole car shake from the engine? If so, could also be a failing battery/alternator. Low rpms = low voltage/current = no spark. Had the same problem, and would be at its worst when I restart the engine after a short trip, I could feel the whole car shaking from the engine/cylinders not firing. Edited January 4, 2019 by giiyanman Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 5, 2019 Share Posted January 5, 2019 (edited) any exhaust leaks before the cat will also make the car hunt idle Edited January 9, 2019 by RumbleRumble Link to comment Share on other sites More sharing options...
tmBH5 Posted January 6, 2019 Author Share Posted January 6, 2019 By idling problem, you mean you feel engine misfires, CEL comes on intermittently and you can feel the whole car shake from the engine? If so, could also be a failing battery/alternator. Low rpms = low voltage/current = no spark. Had the same problem, and would be at its worst when I restart the engine after a short trip, I could feel the whole car shaking from the engine/cylinders not firing. sometimes it feels like misfiring Link to comment Share on other sites More sharing options...
tmBH5 Posted January 6, 2019 Author Share Posted January 6, 2019 any exhaust leaks before the cat will also make the car hunt idle i will take note of that.... Link to comment Share on other sites More sharing options...
tmBH5 Posted January 6, 2019 Author Share Posted January 6, 2019 By idling problem, you mean you feel engine misfires, CEL comes on intermittently and you can feel the whole car shake from the engine? If so, could also be a failing battery/alternator. Low rpms = low voltage/current = no spark. Had the same problem, and would be at its worst when I restart the engine after a short trip, I could feel the whole car shaking from the engine/cylinders not firing. btw what is CEL? Link to comment Share on other sites More sharing options...
giiyanman Posted January 7, 2019 Share Posted January 7, 2019 btw what is CEL? Check engine light. Link to comment Share on other sites More sharing options...
tmBH5 Posted January 8, 2019 Author Share Posted January 8, 2019 Check engine light. There is no problem with the engine light... It doesn't turned ON while the engine runs.... Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 9, 2019 Share Posted January 9, 2019 Have you check the all the vacuum hoses yet? There should be a routing diagram on the inside of the hood, at least my USDM one does. Link to comment Share on other sites More sharing options...
tmBH5 Posted January 9, 2019 Author Share Posted January 9, 2019 anyone here have the vacum diagram for JDM specs?.. i totally have zero knowledge bout this car..... Link to comment Share on other sites More sharing options...
giiyanman Posted January 24, 2019 Share Posted January 24, 2019 Are you talking about a diagram on ALL the hose connections? There are a few resources floating around. Try putting your car number (found under the hood, in the format of BE5-XXXXXX) into partsouq.com and look around. Another is a full maintenance manual for same year Liberty's (Australian version of the Legacy), basically same as JDM spec but tuned down for Australia's lower octane gas. Link to comment Share on other sites More sharing options...
AgentSmith Posted January 27, 2019 Share Posted January 27, 2019 There is no problem with the engine light... It doesn't turned ON while the engine runs.... I’m not sure if you really understand the question. Just to be sure what we are talking about is the CEL. Check for any diagnostic errors. You will need a specific tool for this. Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
