RabidWombat Posted January 2, 2019 Share Posted January 2, 2019 https://www.popularmechanics.com/cars/a19086/warming-up-your-car-in-the-cold-just-harms-engine/ I'm just curious for people's thoughts on the matter. This makes sense, assuming your can keep the engine load down. Link to comment Share on other sites More sharing options...
Notorious Posted January 3, 2019 Share Posted January 3, 2019 No need to ever warm up the car really, even in zero temperatures just let it run for 20-30 seconds before driving and you’re fine as long as you drive gently until it is warmed up from the drive. Is it absolutely terrible for your engine if you do let it idle? Debatable. Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 3, 2019 Share Posted January 3, 2019 (edited) Been warming up my cars for more than 40 years and never had a bit of trouble with them for doing it. Sorry, but that is a fallacy. All the way back from carbs to the first electronically controlled fuel injection systems, it's never been a problem and that myth has been propagated for a very long time. Engines benefit from warming up because it allows all of the different metal alloys within the engine to stabilize. ESPECIALLY a turbo engine as you initially start between 80-90 psi for oil pressure. Oil pressure when cold is important as it can literally spin rod bearings if the oil is not allowed to warm to it's operating viscosity. Normal running idling oil pressure is between 10-20 psi at idle and about 45-50 psi at highway speeds, and that's once it's warm. It's been that way for a very long time and will be that way for many years to come, on all sizes and types of 4 stroke engines. I know there will be a lot of people on here that will disagree, but the reality is that it does not hurt the engine to let it warm up. Let it idle for an hour? A bit excessive, but still won't hurt a thing. Edited January 3, 2019 by JmP6889928 Link to comment Share on other sites More sharing options...
whitexc Posted January 3, 2019 Share Posted January 3, 2019 I agree.....I like the pistons to be round before moving the gear selector. It may not be as long for the LGT but my Cummins idles for at least 10 mins or a temp of 100*F before moving. I feel it is better for fluids to build some heat as well. Link to comment Share on other sites More sharing options...
Zac88 Posted January 3, 2019 Share Posted January 3, 2019 in the winter I start mine, brush off the snow and then drive it. Nicely ofcourse until the coolant needle is moving. Link to comment Share on other sites More sharing options...
ehsnils Posted January 3, 2019 Share Posted January 3, 2019 Same procedure as always - start the engine, scrape off the ice/snow from the windows (and snow from the rest of the car if it's there) and then start to drive. 1. If the engine doesn't start there's no point in removing ice/snow. 2. The first minute of warm-up is sufficient for the engine to settle the worst of the issues and get the oil flowing to all parts. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 3, 2019 Share Posted January 3, 2019 What he ^ said. The engine warms up quicker driving it. Been doing it this way for many years. saves gas too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
CTATV Posted January 3, 2019 Share Posted January 3, 2019 When it’s cold out I tend to let my vehicles warm up for at least 10 minutes Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
KRYPTO Posted January 4, 2019 Share Posted January 4, 2019 your temp gauge will have a little blue light that will let you know when engine is warm enough to drive (in boost) Link to comment Share on other sites More sharing options...
nevets27 Posted January 4, 2019 Share Posted January 4, 2019 If possible plug in the block heater if equipped. Or install a block heater. If you want the engine to warm up much quicker and have the fluids warmer for when the engine turns over. Link to comment Share on other sites More sharing options...
chato Posted January 4, 2019 Share Posted January 4, 2019 just judging by noise, forged pistons seem to appreciate at least a little warm up before driving Link to comment Share on other sites More sharing options...
awfulwaffle Posted January 5, 2019 Share Posted January 5, 2019 just judging by noise, forged pistons seem to appreciate at least a little warm up before driving And that's in New Mexico! Link to comment Share on other sites More sharing options...
Guest Posted January 5, 2019 Share Posted January 5, 2019 Been warming up my cars for more than 40 years and never had a bit of trouble with them for doing it. Sorry, but that is a fallacy. All the way back from carbs to the first electronically controlled fuel injection systems, it's never been a problem and that myth has been propagated for a very long time. Engines benefit from warming up because it allows all of the different metal alloys within the engine to stabilize. ESPECIALLY a turbo engine as you initially start between 80-90 psi for oil pressure. Oil pressure when cold is important as it can literally spin rod bearings if the oil is not allowed to warm to it's operating viscosity. Normal running idling oil pressure is between 10-20 psi at idle and about 45-50 psi at highway speeds, and that's once it's warm. It's been that way for a very long time and will be that way for many years to come, on all sizes and types of 4 stroke engines. I know there will be a lot of people on here that will disagree, but the reality is that it does not hurt the engine to let it warm up. Let it idle for an hour? A bit excessive, but still won't hurt a thing. Many people do things wrong all their lives... Idling does not do much good, in particular it does not warm up other drivetrain parts. How much oil fuel dilution is an issue is debatable, but there are no benefits from excessive idling (>30 secs). Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 5, 2019 Share Posted January 5, 2019 Many people do things wrong all their lives... Idling does not do much good, in particular it does not warm up other drivetrain parts. How much oil fuel dilution is an issue is debatable, but there are no benefits from excessive idling (>30 secs). I'm sure you have done wrong things all your life-it shows in your post. Having been working on cars for almost 50 years and building engines for everything from standard passenger cars to extreme high performance race cars and off road trucks, I've never seen an engine damaged by idling. Go to a race and see if they idle the cars before putting them on the track. If there was going to be damage, they wouldn't do it. If you have enough oil/fuel dilation to measure, then you have other problems and they're serious. You are correct about the drivetrain, but we're not talking about the drivetrain here, now are we. Link to comment Share on other sites More sharing options...
whitexc Posted January 5, 2019 Share Posted January 5, 2019 I feel so bad for a generator or a power washer that goes from cold to balls out in a half-a-second. It just makes me cringe regardless of oil type, etc. I know performance engines are different but if you look at diesel pulling tractors or alcohol tractors, they warm them up and get heat in the turbos before hammering down. Same with drag cars...not hot but some heat in them before hammer time. I have always started and idled my vehicles and will continue to do so. It was around 40F today and my diesel took about 7 mins to reach my 80F departure temp. Even at 80F I give it just enough to get it to move. To me....worth the go go. Link to comment Share on other sites More sharing options...
Guest Posted January 5, 2019 Share Posted January 5, 2019 I'm sure you have done wrong things all your life-it shows in your post. Having been working on cars for almost 50 years and building engines for everything from standard passenger cars to extreme high performance race cars and off road trucks, I've never seen an engine damaged by idling. Go to a race and see if they idle the cars before putting them on the track. If there was going to be damage, they wouldn't do it. If you have enough oil/fuel dilation to measure, then you have other problems and they're serious. You are correct about the drivetrain, but we're not talking about the drivetrain here, now are we. As I said wether idling causes issues is debatable, and I don't have enough data to claim one way or another. In any case, I tend to think that issues/damages would be minimal and relevant to long term engine reliability. Race cars idling as an argument? Truly, no comment.... Link to comment Share on other sites More sharing options...
Guest Posted January 5, 2019 Share Posted January 5, 2019 (edited) I feel so bad for a generator or a power washer that goes from cold to balls out in a half-a-second. It just makes me cringe regardless of oil type, etc. I know performance engines are different but if you look at diesel pulling tractors or alcohol tractors, they warm them up and get heat in the turbos before hammering down. Same with drag cars...not hot but some heat in them before hammer time. I have always started and idled my vehicles and will continue to do so. It was around 40F today and my diesel took about 7 mins to reach my 80F departure temp. Even at 80F I give it just enough to get it to move. To me....worth the go go. Oh, don't get me started on all the bros idling their diesels all the ******* time, not just when cold, while shopping or in a restaurant. I always have to fight the desire to take their keys and throw them away.... And folks claim cold idling diesel is just as bad... Edited January 5, 2019 by unclemat Link to comment Share on other sites More sharing options...
Guest Posted January 5, 2019 Share Posted January 5, 2019 Including Cummins themselves.... https://www.cumminsforum.com/forum/technical-service-bulletins-recall-support/549280-fuel-requirements-cummins-engines-service-bulletin-3379001-a.html Engine Idling CAUTION Do not idle the engine for excessively long periods of time with engine coolant temperature below the minimum specification found in the applicable engine Owner's Manual. This can result in fuel dilution of the lubricating oil, carbon build up in the cylinder, cylinder head valve sticking, and/or reduced performance. Link to comment Share on other sites More sharing options...
twisneski Posted January 5, 2019 Share Posted January 5, 2019 My wagon is not garaged. My general MO* in Michigan winters: Start car, turn on heated seat, turn on front/rear defrosters if glass scraping required. If scraping required, do so while car idles, drive when scraping complete. If no scraping required, drive immediately. Always drive mindfully until temp needle stabilizes. *If single digit temps or below...I'm probably going to let it idle for a few minutes before driving, scraping or no scraping. Link to comment Share on other sites More sharing options...
snm95ls Posted January 5, 2019 Share Posted January 5, 2019 If you're that concerned, get a block heater. They are wonderful. Agree with twisneski. Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 5, 2019 Share Posted January 5, 2019 My rule is min of 30 seconds regardless of temp. if its under 40 degrees F ill idle for 1-5 mins, but drive very slow and 2.5k shifts until the coolant gets to temp then 2 mins after coolant at temp I'll start romping. Engineering Explained- Link to comment Share on other sites More sharing options...
whitexc Posted January 5, 2019 Share Posted January 5, 2019 Oh, don't get me started on all the bros idling their diesels all the ******* time, not just when cold, while shopping or in a restaurant. I always have to fight the desire to take their keys and throw them away.... And folks claim cold idling diesel is just as bad...Is your second car a Prius? Sent from my moto z3 using Tapatalk Link to comment Share on other sites More sharing options...
HDTurbo Posted January 5, 2019 Share Posted January 5, 2019 My rule is min of 30 seconds regardless of temp. if its under 40 degrees F ill idle for 1-5 mins, but drive very slow and 2.5k shifts until the coolant gets to temp then 2 mins after coolant at temp I'll start romping. Engineering Explained- Athletes warm up, good advice for cold cars! Good info on his channel. Link to comment Share on other sites More sharing options...
Guest Posted January 5, 2019 Share Posted January 5, 2019 Is your second car a Prius? Sent from my moto z3 using Tapatalk Hardly. 5 cars in the fleet with the average number of cylinders being 6. Only one is actually six cylinder. I will let you solve the puzzle. Excessive idling is wasteful, harmful, stupid and in many places illegal. There are many idiots around, including this forum, who have no problem with any of these, sadly. Link to comment Share on other sites More sharing options...
whitexc Posted January 6, 2019 Share Posted January 6, 2019 Hardly. 5 cars in the fleet with the average number of cylinders being 6. Only one is actually six cylinder. I will let you solve the puzzle. Excessive idling is wasteful, harmful, stupid and in many places illegal. There are many idiots around, including this forum, who have no problem with any of these, sadly.Word. Wheel of Fortune is for puzzle solving. Sent from my moto z3 using Tapatalk Link to comment Share on other sites More sharing options...
