ukpr Posted January 2, 2019 Share Posted January 2, 2019 Greetings everyone and a Happy New Year to all! I'm connecting everything back up from an EJ25 engine swap into a 2003 Legacy L Wagon that I just picked up. Everything has a home...except for one wire that I need your help in identifying. This wire comes off the main harness which is attached to the back wall of the engine. Underneath the sheathing, it is a single white wire with a blue stripe and looks to be about a 14 ga wire. The other clue is that the connector in the picture was gunked in grime which suggests to me that it wasn't being used for anything. Am I correct? I hope that someone can run out to their 3rd Gen and take a look to conform for me. While I'm here...is there anything else that I need to watch out for prior to thinking I'm done? The manifold I was able to take of the damaged Legacy engine and everything else appears to bolt/connect up. Thanks in advance, Geoff Link to comment Share on other sites More sharing options...
ehsnils Posted January 2, 2019 Share Posted January 2, 2019 Is it a manual or automatic gearbox? Earlier it was not unusual to have a common wiring harness for manual and auto gearbox vehicles. Link to comment Share on other sites More sharing options...
ukpr Posted January 2, 2019 Author Share Posted January 2, 2019 Thanks for your reply: its an automatic. Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 2, 2019 Share Posted January 2, 2019 (edited) looks like the connector for the washer pump for the rear window. Goes by the washer fluid bottle. If not check the brake master/reservoir it also has a connector that should be plugged in for the low brake fluid light. Edited January 2, 2019 by RumbleRumble Link to comment Share on other sites More sharing options...
ukpr Posted January 3, 2019 Author Share Posted January 3, 2019 You're close Rumble in that it exits the harness at the same point the brake MC connector exits, but it's not that. Same with the washer bottle connectors. Plus all of those are 2 terminal connectors but the one I'm questioning is a single wire with a single female blade connector. Link to comment Share on other sites More sharing options...
ukpr Posted January 3, 2019 Author Share Posted January 3, 2019 Hooked up a multimeter to it and I think I lucked out in that it tested continuity for ground. Doesn't explain what it's for, but at least I now know that I'm not robbing power to anything... Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 3, 2019 Share Posted January 3, 2019 goes on the back of the starter. Link to comment Share on other sites More sharing options...
ukpr Posted January 3, 2019 Author Share Posted January 3, 2019 You're officially awesome. Thank you! Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 4, 2019 Share Posted January 4, 2019 anytime, cheers. Link to comment Share on other sites More sharing options...
