59ctd Posted December 30, 2018 Share Posted December 30, 2018 I just purchased the factory sat receiver unit for my 2009 GT sedan. Looking for the antenna now. I've read about placing the antenna in the rear under the third brake light housing but from underneath I do not see any access. Does it fit between the rear deck and the plastic housing or am I missing something else? Link to comment Share on other sites More sharing options...
nevets27 Posted December 30, 2018 Share Posted December 30, 2018 Stock location is top right/passenger side of the windshield. At least I'm pretty sure that's what that thing is there. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 30, 2018 Share Posted December 30, 2018 I put mine up behind the mirror. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
59ctd Posted December 30, 2018 Author Share Posted December 30, 2018 I put mine up behind the mirror. I am thinking about the same thing - up above the mirror. Can the antenna be stuck under where the black edging is along the top middle? Unsure how to best describe it - the black area above mirror that looks like a bunch of small dots. I know the antenna connector is there under the radio / center console but I am unsure where it runs to. Likely the other end is up by the mirror somewhere - ? Link to comment Share on other sites More sharing options...
apexi Posted December 31, 2018 Share Posted December 31, 2018 Diagrams aren't the best, I'll post anyway since they might help. Legacy instructions start on page 7. https://www.subarupartsdeal.com/resources/installation/SPD/18_063791-h621sxa100.pdf Link to comment Share on other sites More sharing options...
Max Capacity Posted January 1, 2019 Share Posted January 1, 2019 (edited) Mine is on those black dots. I don't see it from the drivers seat. Just drove the Spec and noticed I put it under the black dot's behind the drivers side of the rear view mirror. The e-z pass is on the other side. Edited January 1, 2019 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Infosecdad Posted January 1, 2019 Share Posted January 1, 2019 Mine is a magnetic mount and sitting on my roof right in front of the rear gate. Link to comment Share on other sites More sharing options...
grovlet Posted January 3, 2019 Share Posted January 3, 2019 I actually have mine right on the dash - just Velcro in place - works just fine.... Link to comment Share on other sites More sharing options...
59ctd Posted December 24, 2019 Author Share Posted December 24, 2019 So I have procrastinated on install for a year. Thinking about this again. 2009 LGT here. I have a stock XM radio and a small magnet mount antenna instead of the windshield hockey puck style. Based on your responses I think I will just Velcro the antenna to the dash on the driver side up by the defrost vents. For the receiver unit, I have not been able to find the OEM metal mounting brackets so I am expecting to just fashion my own mounting system/brackets out of thin metal stock I can find lying around. This antenna is supposed to be external so does anyone foresee issues with it on the dash vs outside on the roof? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 25, 2019 Share Posted December 25, 2019 As said above, just stick it up behind the mirror, its out of sight. Mine has been there since I installed it by in 2011. Make sure you write down the units numbers so you can give it the person on the phone when sitting up the service. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
