Above_Bored Posted December 29, 2018 Share Posted December 29, 2018 So, my radiator blew on the way to work, causing a major overheat. Fixed it, but now I'm getting a P0026, running rough, and had a really bad stutter at about 4k rpm one time, not repeated. Should I be worried about head gaskets? 07 2.5i, 50k on the engine, 243k total (long story there). Running Royal Purple oil, last changed about 5k miles ago. No loss of oil that I've noticed, otherwise runs great, daily driver with a 50mi commute. Link to comment Share on other sites More sharing options...
relative4 Posted December 29, 2018 Share Posted December 29, 2018 The P0026 is probably unrelated to the overheat unless you blew a head gasket severely enough to foul an OCV with coolant. Pull, inspect, clean, and swap your OCVs, then clear codes and test drive. What is the age, type, and level of your oil? Link to comment Share on other sites More sharing options...
