1-3-2-4 Posted December 26, 2018 Share Posted December 26, 2018 Anyone know the front rotor size for the GT? I got the wrong size which I thought were the right size but they were too small. Link to comment Share on other sites More sharing options...
Infosecdad Posted December 26, 2018 Share Posted December 26, 2018 https://www.amazon.com/gp/product/B003K1DGJS Centric 120.47024 will work great, I have the cryo variant of it. It's 316.5 diameter. Link to comment Share on other sites More sharing options...
whitetiger Posted December 26, 2018 Share Posted December 26, 2018 ^those are way too pricey. try these centrics instead. - https://www.rockauto.com/en/moreinfo.php?pk=1279939&cc=1430733&jsn=393 same exact centric Part# for half the price. $44 per rotor. Link to comment Share on other sites More sharing options...
Notorious Posted December 26, 2018 Share Posted December 26, 2018 About double the price for the cryo treatment, hmmm. Link to comment Share on other sites More sharing options...
Infosecdad Posted December 26, 2018 Share Posted December 26, 2018 Yep, about $30-40 per rotor for the cryo; I was curious to test the longevity with it. We'll see how it does over the years. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 26, 2018 Author Share Posted December 26, 2018 I got the Raybestos 980361FZN Link to comment Share on other sites More sharing options...
apexi Posted December 27, 2018 Share Posted December 27, 2018 The raybestos website says those should fit. If they are smaller than 316mm, I wonder if the non-turbo rotors were put in the box by accident? Part Number:980361FZN Part Description: Disc Brake Rotor Sub-Brand:Element3 Brake Rotor Diameter, Outer: 12.429 in / 315.7 mm Brake Rotor Thickness, Discard:1.102 in / 28.0 mm Brake Rotor Thickness, Nominal:1.183 in / 30.0 mm Link to comment Share on other sites More sharing options...
Max Capacity Posted December 27, 2018 Share Posted December 27, 2018 See post 256, https://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238p7.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
