Bdb Posted December 25, 2018 Share Posted December 25, 2018 I have a 2009 Legacy Special Edition, with the 17 inch alloy wheels. I have a set of 215/60r16 snow tires I would like to run on this vehicle, so I need a set of 16/6-8 inch wheels. Will the 16 inch wheels off of other legacy's or maybe impreza's fit? Link to comment Share on other sites More sharing options...
AWDFTW Posted December 25, 2018 Share Posted December 25, 2018 It should. Think the LGT was the only one with the 17" requiring calipers. Link to comment Share on other sites More sharing options...
Bdb Posted December 25, 2018 Author Share Posted December 25, 2018 Thank you. I assumed wheels from other Legacy's would fit, but wanted to be sure. I also didn't know if the offset on an Impreza wheel would be close enough to run on this car. Link to comment Share on other sites More sharing options...
Bdb Posted December 26, 2018 Author Share Posted December 26, 2018 I found a set of wheels on the local craigslist here where a guy is selling a set of wheels off of his 2008 Forester. The specs on the wheels are 16 x 6.5, 55 offset, 5x100mm Bolt Pattern. Assuming no caliper clearance issues, these should be the correct bolt pattern and offset for the car, right? Just wanting to double check before pulling the trigger. Link to comment Share on other sites More sharing options...
