2006Leggy Posted December 12, 2018 Share Posted December 12, 2018 Hey everyone - I’ve searched the forums and can’t seem to find my answer so I’m asking you guys for help! Recently my 06 legacy threw a check engine light for p0442 and started smelling gas around rear passenger side of car. I checked the filler neck and looks to be in good shape with exception to one area of surface rust but couldn’t see any pinhole leaks. Here’s my problem, after further inspection, I noticed one of the evap tubes that goes into the tank and broken off, it looks like the nipple rusted and broke off. Now I’m sure the proper fix is for a new tank but the cost to replace the tank is now close to what the car is worth. I’ve attached a couple pictures of the issue along with a picture I found on internet from someone who had the same issue. While replacing the tank is correct way to do it, could anyone provide possibly any other solutions that might be able to fix my problem? I was thinking maybe a 2-part epoxy or some other fitting I could get into that hole in the tank? I also read about someone feeding that line back into the filler neck bend where enters the tank? Suggestions anyone? Link to comment Share on other sites More sharing options...
2006Leggy Posted December 12, 2018 Author Share Posted December 12, 2018 Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
Tronic Posted December 12, 2018 Share Posted December 12, 2018 Wow you guys get some corrosion on your cars, I presume your in the UK where they pour salt all over the roads ? What a mess it makes of your cars, things rust out and fall off that are simply never a problem in other countries. I think I would have to put in a jet wash pad that the car would have to sit on for 1 minute every time I came back in during the winter. Link to comment Share on other sites More sharing options...
covertrussian Posted December 12, 2018 Share Posted December 12, 2018 Well that's pretty unsafe to weld that thing, big kaboom, so think of non sparking methods. If the tank is thick enough you might be able to just TAP it for 1/8NPT and just screw in a new 1/8NPT nipple. If it's not thick enough, JB Weld or QuikSteel might actually be good enough. Believe it or not, I'm using QuikSteel to hold my IAT sensors to the intercooler plastics, and it's holding to 14psi! 05 LGT 16G 14psi 290whp/30mpg 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg Link to comment Share on other sites More sharing options...
Max Capacity Posted December 12, 2018 Share Posted December 12, 2018 (edited) FWIW, last year I had a buddies body shop replace my gas tank and fuel filler pipe. Sorry I can't remember the total cost right now. I may have the receipt in the car. Boy the things I do for you guy's. had to take my slippers off put my shoes back on and coat and go out to the car. It's 25F outside. It was also the list receipt in the pile. I had to look through them all... $1331. parts and labor. Edited December 12, 2018 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 13, 2018 Share Posted December 13, 2018 FWIW, last year I had a buddies body shop replace my gas tank and fuel filler pipe. Sorry I can't remember the total cost right now. I may have the receipt in the car. Boy the things I do for you guy's. had to take my slippers off put my shoes back on and coat and go out to the car. It's 25F outside. It was also the list receipt in the pile. I had to look through them all... $1331. parts and labor. Yeah,yeah....pooe old guy...... Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 13, 2018 Share Posted December 13, 2018 POOR old guy...damn calluses...LOL Link to comment Share on other sites More sharing options...
Max Capacity Posted December 13, 2018 Share Posted December 13, 2018 That included the labor to cut a hole in the frame rail to remove and weld in a new nut for one of the chassis bolts. Overall I'm glad I paid the man. The job is not a quick easy job. At my age, I know what I want to do and can pay the man when I need to. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
2006Leggy Posted December 14, 2018 Author Share Posted December 14, 2018 Well that's pretty unsafe to weld that thing, big kaboom, so think of non sparking methods. If the tank is thick enough you might be able to just TAP it for 1/8NPT and just screw in a new 1/8NPT nipple. If it's not thick enough, JB Weld or QuikSteel might actually be good enough. Believe it or not, I'm using QuikSteel to hold my IAT sensors to the intercooler plastics, and it's holding to 14psi! Thanks! I may try that first and see what happens before attempting to replace the tank - I also read that a product called Seal All seems to work pretty well for stuff like this Link to comment Share on other sites More sharing options...
2006Leggy Posted December 14, 2018 Author Share Posted December 14, 2018 That included the labor to cut a hole in the frame rail to remove and weld in a new nut for one of the chassis bolts. Overall I'm glad I paid the man. The job is not a quick easy job. At my age, I know what I want to do and can pay the man when I need to. I appreciate you heading out in the cold to check the cost! That’s roughly the same quote I got for a shop near me so now I atleast know they are in the right ballpark Does anyone know where this particular evap goes to? Or maybe what would happened if you just plugged the hole in the tank and the hose entirely?! Link to comment Share on other sites More sharing options...
wai_pang2 Posted December 17, 2018 Share Posted December 17, 2018 Good luck, I've been driving with that code for close to a year, I've just dropped my fuel tank to replace with a new tank because of that barbed nipple. Link to comment Share on other sites More sharing options...
