Brock Samson Posted December 11, 2018 Share Posted December 11, 2018 I went through my maintenance log tonight, looking at 8 years of ownership of my 2005. I still love the car, especially with the upgrades but I'm seriously considering whether its been worth it. I've easily plowed half the purchase price back into the vehicle in parts...and god forbid all the time and busted knuckles and swearing and other shit. It reads like the "Common maintenance problems" list here and "required maintenance" by the Unabomber over on NASIOC: Clutch (twice now!) Flywheel Turbocharger Both CV axles Both rear hub bearings Power Steering Pump (TWICE!) Alternator Starter Both LCA's Radiator P/S lines and reservoir I'm sure I'm forgetting some things. Anyone know of something not on my list to expect to explode in the next few thousand miles? :lol: Link to comment Share on other sites More sharing options...
Gex Posted December 11, 2018 Share Posted December 11, 2018 14 year old high strung car needs maintenance. Yawn. If you want reliable buy a Civic. Link to comment Share on other sites More sharing options...
ehsnils Posted December 11, 2018 Share Posted December 11, 2018 And how far and hard has it been driven? Distance and how hard it was driven also plays a role in how much you have to put into the car. The only item that shouldn't have been impacted by usage as I see it is the radiator unless you got a rock in it. I suspect that the brake calipers could be a suspect item to come up. But they actually prefer a bit of a tougher driving since they will be heated and exercised then. Parking brake cables are also items that are candidates as I see it. Link to comment Share on other sites More sharing options...
Notorious Posted December 11, 2018 Share Posted December 11, 2018 You pay to play man. I've got 150k on my 05 as well and have replaced almost all the things you mentioned on that list plus more. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 11, 2018 Share Posted December 11, 2018 Only 267 post...I guess you've missed that I've posted here a number of times, I bought my 05 wagon new in late June 2004, I'm well into paying for it the third time. But every time I push my right foot to the firewall the car still brings a big smile to my face. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Somac Posted December 11, 2018 Share Posted December 11, 2018 The only thing suspect on your list is the clutch and PS pump twice, depending on your mileage. Everything else is either a wear item, or expected to give out at some point but not necessarily wear-related like the radiator. Knock on wood, hope your motor doesn't blow up. Link to comment Share on other sites More sharing options...
m sprank Posted December 11, 2018 Share Posted December 11, 2018 Power steering racks tend to leak out of the shaft seal. Shifter linkages tend to go after 150k. TMIC tend to leak by 120k even at stock boost. 4th gen LGT radio/HCAV controls tend to go wacky (3 of mine did) but you can fix them if you are decent at micro soldering. Engines and head gaskets are ALWAYS suspect. Pesky air bag light? Cracked clutch pivot tubes, seized hvac actuators, the list goes on. Its what makes a Subaru a Subaru. They are kinda of like a drug. You know you need to quit, but... Thinking the Forester is it for me. I am "married" to it I have so much invested in it. If the engine or trans goes (again) I might just be pissed enough to burn it. Next car will not be a Subie. 17 years so far and its been rough. LOL. Link to comment Share on other sites More sharing options...
mondtster Posted December 11, 2018 Share Posted December 11, 2018 Pretty much everything on that list would be considered normal wear items that could happen to any 13 year old car. Especially one with higher mileage that is used up. What did you expect? Of the 7 Subarus I've owned so far I haven't had one that I would consider a bad purchase yet. My current car is a 2004 with 260k on it and needs ball joints and wheel bearings but is otherwise good. That doesn't seem to be too much to ask at that kind of mileage. You want something that costs money to maintain, always needs maintenance, and always has the potential to have a $10k+ repair waiting around the corner? Try owning and maintaining a light airplane. The money you spent on 8 years of ownership of a Subaru and think is bad is probably the same or less than what is spent on an average light plane each year. Link to comment Share on other sites More sharing options...
apexi Posted December 11, 2018 Share Posted December 11, 2018 Shifter linkages tend to go after 150k. I've had the ps leak at the shaft seal, cracked clutch fork at the pivot (I think, that's what the dealer said), and airbag light.. I'm at 230k, so you've got me thinking about the shifter linkage.. What usually goes bad and what are the symptoms? Link to comment Share on other sites More sharing options...
m sprank Posted December 12, 2018 Share Posted December 12, 2018 I've had the ps leak at the shaft seal, cracked clutch fork at the pivot (I think, that's what the dealer said), and airbag light.. I'm at 230k, so you've got me thinking about the shifter linkage.. What usually goes bad and what are the symptoms? Super sloppy. Difficult to find gears. Stick goes round the world in a circle. Link to comment Share on other sites More sharing options...
Guest Posted December 12, 2018 Share Posted December 12, 2018 Super sloppy. Difficult to find gears. Stick goes round the world in a circle. Really? I can see them breaking due to corrosion, but just due to age and in CA, I assume? Surprising. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted December 12, 2018 Share Posted December 12, 2018 None of those items are rare failures on vehicles. You would be naive to say other manufacturers don't have the same wearable parts. For what you get, these cars are pretty well built. Link to comment Share on other sites More sharing options...
ehsnils Posted December 12, 2018 Share Posted December 12, 2018 Super sloppy. Difficult to find gears. Stick goes round the world in a circle. Seems like an ordinary VW bus with tail engine. Throw around the stick a few times and hope you got a good gear. Link to comment Share on other sites More sharing options...
Rhitter Posted December 12, 2018 Share Posted December 12, 2018 Super sloppy. Difficult to find gears. Stick goes round the world in a circle. The solution is just do every single shifter linkage bushing you can. It only makes it more noisy, otherwise feels great. For a Subaru 5mt..... My OBXT build Link to comment Share on other sites More sharing options...
m sprank Posted December 13, 2018 Share Posted December 13, 2018 Really? I can see them breaking due to corrosion, but just due to age and in CA, I assume? Surprising. They wear out. Sometimes there is no bushing left, just the metal tube. Ocean air does not help. I am familiar with many brands of car. I was Datsun/Nissan specific for many years. I have lots of experience with Honda (cars and bikes), Toyota, Yamaha and HD. They all have their quirks. But in all honesty my Subarus always needed MORE than any other cars I have built in 30+ years of it. Love/Hate relationship LOL. Link to comment Share on other sites More sharing options...
Gabo Posted December 13, 2018 Share Posted December 13, 2018 The solution is just do every single shifter linkage bushing you can. It only makes it more noisy, otherwise feels great. For a Subaru 5mt..... I did this only to find the shifter linkage was the culprit. As Mike stated the ting was in horrible shape. I still have it around, maybe I'll post a picture. Link to comment Share on other sites More sharing options...
Gabo Posted December 13, 2018 Share Posted December 13, 2018 They wear out. Sometimes there is no bushing left, just the metal tube. Ocean air does not help. I am familiar with many brands of car. I was Datsun/Nissan specific for many years. I have lots of experience with Honda (cars and bikes), Toyota, Yamaha and HD. They all have their quirks. But in all honesty my Subarus always needed MORE than any other cars I have built in 30+ years of it. Love/Hate relationship LOL. I use to own a Mazdaspeed Protege, best handling car I've ever owned but it was just as needy or even more than my Spec B so far. Link to comment Share on other sites More sharing options...
m sprank Posted December 13, 2018 Share Posted December 13, 2018 I use to own a Mazdaspeed Protege, best handling car I've ever owned but it was just as needy or even more than my Spec B so far. I had bad luck with Mazdaspeed 3's. I would not recommend modifying one of those. I almost bought a Speed6. Glad I did not in retrospect. The trans was total crap and did not hold. I BEAT the ever loving snot out of my B13 turbo Sentra I built right after high school. Bought the car for under $6k new off the lot and dropped 6 times that in mods. It ran 12's at Carlsbad and I put over 115k on it before I sold it (and it was NOT broken). Stock shortblock, thing never broke (but I did have it upside down once). It was the energizer bunny of modding. We had very few major issues with all my Dads (full race) 510's. I guess I started spoiled. Link to comment Share on other sites More sharing options...
Gabo Posted December 13, 2018 Share Posted December 13, 2018 I had bad luck with Mazdaspeed 3's. I would not recommend modifying one of those. I almost bought a Speed6. Glad I did not in retrospect. The trans was total crap and did not hold. I BEAT the ever loving snot out of my B13 turbo Sentra I built right after high school. Bought the car for under $6k new off the lot and dropped 6 times that in mods. It ran 12's at Carlsbad and I put over 115k on it before I sold it (and it was NOT broken). Stock shortblock, thing never broke (but I did have it upside down once). It was the energizer bunny of modding. We had very few major issues with all my Dads (full race) 510's. I guess I started spoiled. Honda's where my equivalent of your Sentra, minus the upside/down. I owned two civics, a RSX Type S and now an Acura RDX. Had superchargers and turbochargers, this was of course before ethanol was a thing. I'm currious how those cars would have handled the ethanol. Link to comment Share on other sites More sharing options...
Brock Samson Posted December 14, 2018 Author Share Posted December 14, 2018 Its only got 115k miles on it, never been autocrossed or tracked. Some spirited driving on the road but I don't hard launch or stuff like that. So these wear items seem to have worn out pretty damn quickly. I had a 13 year old BMW M3 that had required nothing like this much work. Everyone here is right, they're still a very lovable car to drive...and its not like there's a lot (any?) USDM manufacturers making an AWD, turbocharged, MT wagon. For the other things people listed here- I've already rebuilt the brake calipers 2 years ago. Shifter linkage I inspected last week while doing the clutch, as well as a new pivot point and clutch fork. All new shifter bushings REALLY improved the feel of the shifter. Also I forgot some things: -Harmonic balancer exploding on the freeway -AC compressor idler pulley disintegrating -Usual leaky valve cover And of course everything is compounded by salted roads rusting things up and causing bolt heads to twist off regularly. One thing is for sure, without you guys and this amazing community, I never would have stuck with it. There's no way I could have ever done all this work myself, and learned so much without the posts here. I've never once taken Peggy the Leggy to a mechanic, and only ever to the stealership for warranty work. Thanks you all! Link to comment Share on other sites More sharing options...
Dishwasher Posted December 14, 2018 Share Posted December 14, 2018 When I bought a Legacy GT, I hadn't owned a turbo car before, and had never done more than swap an intake on a car or changed the oil. Thanks to this forum I've learned a ton. I've changed my timing belt, changed brake fluid, coolant, transmission fluid, differential fluid, power steering fluid. I've swapped calipers, coil packs, spark plugs, valve cover gaskets, every major exhaust component, installed a new sound system, learned how to solder wires, changed out a very wide variety of suspension bushings. Changed a clutch (not my own), and helped a number of people in my local community fix their cars as well. The only thing I haven't done is pulled the motor, but I'm confident I can/will when it becomes necessary. Subarus have a way of making people become halfway decent wrenches (or financially insolvent). Link to comment Share on other sites More sharing options...
Guest Posted December 14, 2018 Share Posted December 14, 2018 Indeed, while I wrenched on cars before, LGT took it to the next level (heh, lost count how many times I pulled the motor...). It also helps these cars are exceptionally easy to work on. Link to comment Share on other sites More sharing options...
whitetiger Posted December 14, 2018 Share Posted December 14, 2018 Subarus have a way of making people become halfway decent wrenches (or financially insolvent). 1st fiscally insolvent, then halfway decent wrenches out of necessity. Link to comment Share on other sites More sharing options...
ehsnils Posted December 15, 2018 Share Posted December 15, 2018 Indeed, while I wrenched on cars before, LGT took it to the next level (heh, lost count how many times I pulled the motor...). It also helps these cars are exceptionally easy to work on. I agree - they are easy to work on. Most of the items you usually want to access are easy to get to without a lot of special tools or the need of it being a two man job. I once encountered a car where you had to be two persons just to manage a pulley - one from above and one from below the car, both with socket extenders. Link to comment Share on other sites More sharing options...
boxkita Posted December 16, 2018 Share Posted December 16, 2018 If you have this kind of wear and don't track it, perhaps you should. Your wear parts might increase tho. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
