BLBostonLegacy Posted December 8, 2018 Share Posted December 8, 2018 Getting ready to replace my drivers side lower ball joint. I came up with a “tool” to use to pull out the old one. What I haven’t come up with, any tricks or advice for reinstallation? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
apexi Posted December 8, 2018 Share Posted December 8, 2018 (edited) Be very careful with the pinch bolt that holds the top of the ball joint, there's a good chance it will break. If it breaks, you'll have to drill it out, or replace the steering knuckle. If you can use heat like in the video below, seems like that's the best way to attack it. I didn't, I just tried penetrating oil for a week, still broke mine. Edited December 8, 2018 by apexi Link to comment Share on other sites More sharing options...
r.lee89 Posted December 8, 2018 Share Posted December 8, 2018 I ended up buying 2 new spindles when I did mine. Both bolts were seized but I did get them out with lots of heat. I would try to avoid spreading the spindle where the ball joint gets clamped. I ended up snapping the ear off on one spindle. Once you get it out it's not bad getting it back in just make sure you clean the rust out of the hole. Link to comment Share on other sites More sharing options...
rhino6303 Posted December 8, 2018 Share Posted December 8, 2018 After you pull the ball joint out of the cup, use a wire brush cup in a drill to clean it out. With the bolt out of the knuckle, it should slide in once cleaned. I put antiseize all over the knuckle and ball joint when I install them. Link to comment Share on other sites More sharing options...
