Dalee1104 Posted December 7, 2018 Share Posted December 7, 2018 So I have an 08 spec b with 120k miles on it and most maintenance has been done on it. I love the car but it's still on a stock tune and I know it has more potential. The car is mostly stock but has a custom exhaust and that's about it. My buddy has an 05 lgt which has the same ej255 as the spec b minus some various parts in the heads I believe. I'm broke and was basically curious if there was a way i could unmarry his accessport from his car and load in a off the shelf tune for my car, then unmarry it from mine and marry it back to his. If that is possible what tune should I load in? I've heard many go to stage 2 and be happy with it even without intake mods but I'm not sure what all is needed for stage 2. Also the main thing for me is the car is reliable right now and i still want to be able to safely use it as a daily driver and not have to worry about the reliability. That being said I would like some input from you guys who have probably done this stuff many times before. This is my first turbo car so I'm still learning Link to comment Share on other sites More sharing options...
Gabo Posted December 7, 2018 Share Posted December 7, 2018 Every time you unmarry an accessport the stock map is loaded up. In other words what you want to do is impossible. Link to comment Share on other sites More sharing options...
Dalee1104 Posted December 7, 2018 Author Share Posted December 7, 2018 Damn that sucks, well worth a shot lol thanks anyways! Link to comment Share on other sites More sharing options...
Mr-C Posted December 7, 2018 Share Posted December 7, 2018 Short answer is no....once the AP is unmarried you lose the tune/functions. COBB is not the only tool you can use to reflash your ECU however does require some software/hardware (ie: Tactrix cable,etc...) in order to do so, which is still cheaper than an AP...not very familiar with what is required (I have an AP myself) and I'm sure others no the forum can provide more details/guidance. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 7, 2018 Share Posted December 7, 2018 No the 05-06 AP is different from a 07-09 AP Cobb AP at stage 2 with a 3" down pipe will be fine. For better performance, get a custom tune. The car is safer on the Cobb stage 1 tune than it is on the stock tune. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Dalee1104 Posted December 7, 2018 Author Share Posted December 7, 2018 See I've heard that the stock tunes aren't amazing for these cars. I have a stock downpipe so looks like I'll have to save up for an accessport for stage 1 then once I get the downpipe I'll move up to stage 2 Link to comment Share on other sites More sharing options...
Max Capacity Posted December 8, 2018 Share Posted December 8, 2018 When I first went stage 1, back in Dec 2004 when V1 came out. My thought was, this is how the car should have come from the factory. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ttnio Posted December 8, 2018 Share Posted December 8, 2018 Damn that sucks, well worth a shot lol thanks anyways![/QUOTe that's ok, many people tried with the same question. Link to comment Share on other sites More sharing options...
Dalee1104 Posted December 8, 2018 Author Share Posted December 8, 2018 You guys are always a huge help. I've rebuilt multiple old ej25d engines but when it comes down to turbo cars and all the fancy ecu stuff you get with a car that isn't from the 90's theres just a few more parts to learn Link to comment Share on other sites More sharing options...
