bradlington Posted December 5, 2018 Share Posted December 5, 2018 I have recently replaced exhaust front to back and deleted the CAT. Installed Wide Band O2 sensor which is working well . I have a Launch123 and although this unit reads codes and can reset , reads sensors BUT does not allow recording or logging such as graphs. I am in need of help to identify which Scan type software / hardware interface I can use to log via laptop and possible look at mapping to further understand the workings. I am adding hydrogen and few other changes and do need to accurately record each change to safeguard any issues. Thanks in advance Bradley South Africa Link to comment Share on other sites More sharing options...
AgentSmith Posted December 18, 2018 Share Posted December 18, 2018 Interesting that you adding hydrogen in your system. Which brand are you using or you building it from scratch ?? Also I believe the Subaru is carrying SSM2 protocol. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
bradlington Posted December 20, 2018 Author Share Posted December 20, 2018 I have experimented with some wet cells and had a spiral HHO generator in my vehicle for a short while low output but it worked well and felt it was worth persuing a dry cell version for longivity. From this I have also experimented a little with water vapor ultrasonic and fuel vapor. After much research I decided go for the Unit from HydroclubUSA being a drycell with the Volo chip as part of the kit .Found value in the combined kit and expecting it to arrive before the new year. Last month I added a new stainless steel 50mm exhaust front to back with two cowley straight through boxes - free flow of course- removed CAT as I am running hydrogen , added WBO2 sensor which allows me monitoring the stoich ratio in real time for peace of mind. My model of Legacy is rather frustrating , none of the normal everyday products seem to work - appears a year or two (ECU unit firmware) before the standard was fully compliant across all vehicles - so I can read basics but no logging or graphs. Link to comment Share on other sites More sharing options...
