Dropsix Posted December 3, 2018 Share Posted December 3, 2018 Hey everyone, went to test drive a used 2013 Legacy (non-turbo) with the 6 speed manual last week. I noticed the idle speed was rather high, like closer to the 800rpm range. This was after a good run on the highway too so the motor was at operating temp. Is this normal for this car? My current 2006 legacy idles at about 500rpm IIRC. Otherwise, any other tips for this gen I could look out for? Thanks!! Link to comment Share on other sites More sharing options...
foxrider28 Posted December 3, 2018 Share Posted December 3, 2018 (edited) I do believe this is normal for the 5th gen 2.5i or GT. My GT will idle around 12-1500 rpm on cold start then will settle to somewhere between 700-800 rpm. Only other conrcerns I would have with the car would be the oil consumption recall and if this car was either repaired or outside the vin range. Edited December 3, 2018 by foxrider28 Link to comment Share on other sites More sharing options...
Dropsix Posted December 3, 2018 Author Share Posted December 3, 2018 I do believe this is normal for the 5th gen 2.5i or GT. My GT will idle around 12-1500 rpm on cold start then will settle to somewhere between 700-800 rpm. Only other conrcerns I would have with the car would be the oil consumption recall and if this car was either repaired or outside the vin range. Awesome thanks! I did run the vin on the Subaru Canada site and it is showing that it is eligible to be fixed if it is consuming oil. 8 years/160000kms coverage I believe. From the carfax report I see no issues and the subaru dealer I got in touch with told me a bit of the service history which seemed pretty normal. Link to comment Share on other sites More sharing options...
Sarang Posted December 3, 2018 Share Posted December 3, 2018 Mine idles closer to 800 or 900 rpm, but I always have the AC on. Link to comment Share on other sites More sharing options...
rgeo13 Posted December 3, 2018 Share Posted December 3, 2018 My normal idle when warmed up is 800rpm on the dot. 2011 2.5i 6mt. Link to comment Share on other sites More sharing options...
dgoodhue Posted December 3, 2018 Share Posted December 3, 2018 I think my '12 2.5i 6MT was 625rpm warmed up on the data logs, but it was higher (maybe 800) when the AC is on. The AC is on when the car is in defrost. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 3, 2018 Share Posted December 3, 2018 2013-14 idle is roughly 720ish rpm when in gear stopped or in park when engine is up to operating temp Link to comment Share on other sites More sharing options...
A_A_ron Posted December 4, 2018 Share Posted December 4, 2018 (edited) If you buy the car and it's eligible for the oil (not fuel) consumption fix get it straight to your nearest Subaru dealership and start the consumption test. As long as you start the test before 100k miles you're good to go. They'll have your drive it for 1000 miles I think and then bring it back. If the oil level has dropped by something like 1/2 qt to 1 qt you get a new short block. Don't miss out of that opportunity. Don't worry about the idle rpm too much or let it dissuade you from buying an awesome car. Edited December 4, 2018 by A_A_ron type Build Thread Link to comment Share on other sites More sharing options...
dgoodhue Posted December 4, 2018 Share Posted December 4, 2018 If you buy the car and it's eligible for the fuel consumption fix get it straight to your nearest Subaru dealership and start the consumption test. As long as you start the test before 100k miles you're good to go. They'll have your drive it for 1000 miles I think and then bring it back. If the oil level has dropped by something like 1/2 qt to 1 qt you get a new short block. Don't miss out of that opportunity. Don't worry about the idle rpm too much or let it dissuade you from buying an awesome car. I think you mean oil consumption... Link to comment Share on other sites More sharing options...
Dropsix Posted December 5, 2018 Author Share Posted December 5, 2018 If you buy the car and it's eligible for the oil (not fuel) consumption fix get it straight to your nearest Subaru dealership and start the consumption test. As long as you start the test before 100k miles you're good to go. They'll have your drive it for 1000 miles I think and then bring it back. If the oil level has dropped by something like 1/2 qt to 1 qt you get a new short block. Don't miss out of that opportunity. Don't worry about the idle rpm too much or let it dissuade you from buying an awesome car. Great info! Thanks! Link to comment Share on other sites More sharing options...
