adamh194 Posted November 26, 2018 Share Posted November 26, 2018 2015 legacy 3.6 limited Anyone experiencing a water leak. It rained in NY Saturday and today(Monday) got in car radio wasn't working noticing water on weather mat on front but in the back looked like 2 gallons of water so my amp fried it's not waterproof since it was submerged in water and it wasn't raining that much today I didn't notice anything crazy this morning when I got in at 5 a.m. my backpack even fell In front footwell no major water wtf smh Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
MrCobbs Posted November 27, 2018 Share Posted November 27, 2018 Was this on the passenger or driver’s side? I had a similar issue and the drains for the sunroof were clogged. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
beardman Posted November 27, 2018 Share Posted November 27, 2018 Wondering if there might be sunroof drains that are clogged/frozen. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
adamh194 Posted November 27, 2018 Author Share Posted November 27, 2018 Was this on the passenger or driver’s side? I had a similar issue and the drains for the sunroof were clogged. Sent from my iPhone using TapatalkPassenger most was in rear but it was so much water was sloshing front to back Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
tornichoe Posted November 27, 2018 Share Posted November 27, 2018 Was this on the passenger or driver’s side? I had a similar issue and the drains for the sunroof were clogged. Isn't there a rubber seal around the sun roof? Didn't think water could get it when it is closed... Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted November 28, 2018 Share Posted November 28, 2018 (edited) check the drains for the sunroof, should be one in each corner Edited November 28, 2018 by YeuEmMaiMai Link to comment Share on other sites More sharing options...
adamh194 Posted November 28, 2018 Author Share Posted November 28, 2018 check the drains for the sunroof, should be one in each corner[emoji2962][emoji2962]didn't even know I had those what corners I know the car but lost as to where they might be since it was mentioned I've been opening sunroof sticking my hands all over Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
MrCobbs Posted November 29, 2018 Share Posted November 29, 2018 [emoji2962][emoji2962]didn't even know I had those what corners I know the car but lost as to where they might be since it was mentioned I've been opening sunroof sticking my hands all over Sent from my SM-G950U using Tapatalk Don’t do that you as may damage the track for the sunroof. Just go to a dealer or call them on the phone and ask them how to handle that. They may ask you to come in and fix it for free. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted November 29, 2018 Share Posted November 29, 2018 [emoji2962][emoji2962]didn't even know I had those what corners I know the car but lost as to where they might be since it was mentioned I've been opening sunroof sticking my hands all over Sent from my SM-G950U using Tapatalk the best way is to go under the car and you will find 4 tubes sticking out of the body one each corner near the firewall and rear doors. use a shop vac to suck them out https://www.subarugenuineparts.com/auto-parts/2015/subaru/legacy/2-5i-trim/2-5l-h4-gas-engine/body-cat/sunroof-scat Link to comment Share on other sites More sharing options...
tornichoe Posted November 29, 2018 Share Posted November 29, 2018 the best way is to go under the car and you will find 4 tubes sticking out of the body one each corner near the firewall and rear doors. use a shop vac to suck them out https://www.subarugenuineparts.com/auto-parts/2015/subaru/legacy/2-5i-trim/2-5l-h4-gas-engine/body-cat/sunroof-scat I just tried to find these and located the front 2. Always thought they was some kind of drain up there for emergency; but didn't think it was normal for water to leak through the rubber seal when the sun roof was closed. Never had a problem with any of my cars in the past, so its kinda strange to hear. But a quick google search pulls up quiet a few results, so I guess its common. Link to comment Share on other sites More sharing options...
adamh194 Posted November 30, 2018 Author Share Posted November 30, 2018 Don’t do that you as may damage the track for the sunroof. Just go to a dealer or call them on the phone and ask them how to handle that. They may ask you to come in and fix it for free. Sent from my iPhone using TapatalkI was delicate in my reach but definitely will have to go to dealership since amp doesn't work cause it got submerged in water Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
adamh194 Posted November 30, 2018 Author Share Posted November 30, 2018 (edited) THANK YOU GUYS FOR BEING SO HELPFUL I know this what we do share info but I'm not an ingrate Sent from my SM-G950U using Tapatalk Edited November 30, 2018 by adamh194 Link to comment Share on other sites More sharing options...
MrCobbs Posted November 30, 2018 Share Posted November 30, 2018 No problem and I would notify Subaru of America in case you may invite some outrageous costs as well. I doubt it says in the manual to “keep your drainage hoses clear”. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
08SpecB_DE Posted November 30, 2018 Share Posted November 30, 2018 A quick shot of compressed air into the sunroof drains is all you need to clear them. Dirt and grime builds up then clogs them. If you open the sunroof all the way, you will see a hole in the front corners, they are your drains. Link to comment Share on other sites More sharing options...
