wintergreen Posted November 24, 2018 Share Posted November 24, 2018 I have a car with non-EGR engine swapped into a chassis with an ECU looking for an EGR. Is there a way to jumper or create a mock signal to the ECU? What if I just get the correct harness and plug an EGR into it? Link to comment Share on other sites More sharing options...
RumbleRumble Posted November 24, 2018 Share Posted November 24, 2018 These ECUs are NOT tune-able. They might have swapped ECUs too. Link to comment Share on other sites More sharing options...
moral hazard Posted November 25, 2018 Share Posted November 25, 2018 What if I just get the correct harness and plug an EGR into it? I would look at this option, no reason why it shouldn't work. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted November 25, 2018 Share Posted November 25, 2018 No egr as in everything is there but blocked off or removed OR not even an option on the motor? Link to comment Share on other sites More sharing options...
wtdash Posted November 26, 2018 Share Posted November 26, 2018 See ThIS. But you WILL need the original car's harness and IM. Link to comment Share on other sites More sharing options...
Berge56 Posted November 26, 2018 Share Posted November 26, 2018 You can drill and tap an EGR port into the engine if you still have the EGR intake manifold. I just did this on a 2.2 liter and it worked perfectly. There is a write up out there on how to do it. Link to comment Share on other sites More sharing options...
