rdleg05 Posted November 24, 2018 Share Posted November 24, 2018 asking for help and troubleshooting ideas for hesitation, shuddering, and P0302 CEL on a 2009 2.5i Limited Legacy N/A. Background: 2009 2.5i Limited Legacy non-aspirated (N/A), 4EAT auto trans that my daughter daily's. I did a headgaskets, water pump, idlers, and timing belt in May 2017 due to oil seeping from underside of heads. I also changed sparkplugs while engine was out (NGK FR5AP-11). Car drove well until SEP 2018 when daughter stated that car was shuddering and undriveable due to hesitation along with CEL. I read the codes and it had p0300 along with P0301-P0404. Started checking sparkplug wires and two of them had insulation break apart. New plug wires and an OEM coil were installed as one of the sparkplug wires broke off in the coil. Fast forward to NOV 2018 and shuddering, hesitation and P0302 are back. I checked the interwebs and the usual P0302 troubleshooting came up. I did the following: --I checked wires, all good. --pulled the plugs on cylinders 2 and 4, checked their gap (0.040 in); and also their color. No signs of oil or running lean on the plugs. --plugs re-installed with original plug from cylinder 2 installed into cylinder 4; and original cylinder 4 plug installed into cylinder 2. (I did this to see if the CEL would follow a specific plug). Wife drove the car today and it hesitated and within 30 feet of driving she stopped and told me that the CEL had come on. Upon her return, I read the codes: P0302. Tomorrow, i will do the following: --check for any airleaks into the intake (post MAF). --clean the MAF. Addtional info: --both CV boots are torn and I have OEM CV boots that I will install to repair the drive shafts. (Currently believe that this is not causing the hesitation or CEL as it is drive line not engine related). What am I missing. What troubleshooting ideas can you provide. cheers rdleg05 Link to comment Share on other sites More sharing options...
relative4 Posted November 24, 2018 Share Posted November 24, 2018 Swap fuel injectors between #2 & #4 Pull the learned values Compression test Link to comment Share on other sites More sharing options...
rdleg05 Posted November 27, 2018 Author Share Posted November 27, 2018 Update: short version: injectors #2 and #4 cleaned and installed with injector #2 in cylinder 4 and injector #4 installed in cylinder 2. Car started and idled to start the fuel trim learning and then driven. No hesitation/no shuddering, no CELs On 25 NOV, I pulled the injectors #2 and #4. Got the Bracket of Death off and pulled the injectors. I then proceeded to pull the O-rings off and cleaned teh outside of the injectors and then cleaned the injectors using a 6v battery to pulse the injector while shooting brake cleaner, then Seafoam, and then Carburetor/injector cleaner using a syringe and tubing that fit over the top of the topfeed injector. After several cleaning cycles, I put the injectors aside for the evening. The next evening after work/commute home, i put the injectors O-rings on and then installed the injectors into the intake maniforld. The original injector #2 was installed in cylinder 4 and injector #4 was installed in cylinder 2. Re-installed all pieces removed to get to the injectors, everything torqued to spec and car started. Le the car idle for about 30 min until fans came (to start the fuel trim learning and then drove the car about 5 miles. No hesitation/no shuddering, and no CELs. Told the daughter to drive the car and report to me if there are any CELs or hesitation that occurs while she is driving. More to follow.... cheers rdleg05 Link to comment Share on other sites More sharing options...
Carmania24 Posted November 27, 2018 Share Posted November 27, 2018 Update: short version: injectors #2 and #4 cleaned and installed with injector #2 in cylinder 4 and injector #4 installed in cylinder 2. Car started and idled to start the fuel trim learning and then driven. No hesitation/no shuddering, no CELs On 25 NOV, I pulled the injectors #2 and #4. Got the Bracket of Death off and pulled the injectors. I then proceeded to pull the O-rings off and cleaned teh outside of the injectors and then cleaned the injectors using a 6v battery to pulse the injector while shooting brake cleaner, then Seafoam, and then Carburetor/injector cleaner using a syringe and tubing that fit over the top of the topfeed injector. After several cleaning cycles, I put the injectors aside for the evening. The next evening after work/commute home, i put the injectors O-rings on and then installed the injectors into the intake maniforld. The original injector #2 was installed in cylinder 4 and injector #4 was installed in cylinder 2. Re-installed all pieces removed to get to the injectors, everything torqued to spec and car started. Le the car idle for about 30 min until fans came (to start the fuel trim learning and then drove the car about 5 miles. No hesitation/no shuddering, and no CELs. Told the daughter to drive the car and report to me if there are any CELs or hesitation that occurs while she is driving. More to follow.... cheers rdleg05 Glad to hear everything is working! Hopefully she's (car) not going to do it again. Cheers! Link to comment Share on other sites More sharing options...
TimothyOnline Posted December 4, 2018 Share Posted December 4, 2018 Got the Bracket of Death off and pulled the injectors. You ain't kiddin'! Those fuel pipes and the injector uppermost O-rings are TEMPERAMENTAL! Link to comment Share on other sites More sharing options...
