AWDFTW Posted November 23, 2018 Share Posted November 23, 2018 https://www.facebook.com/marketplace/item/518405025273302/ tl;dr Cobb downpipe with a reported 40K miles of use for $275. Safeish buy or likely trouble? Also, pardon my typo in the tread title. Should say "risky". Link to comment Share on other sites More sharing options...
Notorious Posted November 23, 2018 Share Posted November 23, 2018 40k miles isn’t too much and a used down pipe isn’t risky. You just have to wonder if the catalytic converter is in good shape which it should be. However in your user settings you say you have two NA outbacks, is this for a different car? This down pipe sounds like it’s for a WRX hatch (2008-2011) Link to comment Share on other sites More sharing options...
cryo Posted November 23, 2018 Share Posted November 23, 2018 I see people buy used downpipes all the time and most times are good but keep in mind the quality of the cat. Most are normally only good for about 4-5 years on aftermarket cats so that can cause issues in the long run. Hope that helps. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
AWDFTW Posted November 23, 2018 Author Share Posted November 23, 2018 40k miles isn’t too much and a used down pipe isn’t risky. You just have to wonder if the catalytic converter is in good shape which it should be. However in your user settings you say you have two NA outbacks, is this for a different car? This down pipe sounds like it’s for a WRX hatch (2008-2011) Would be for a 2006 OBXT that I'm buying from a family member in a little over a year. Link to comment Share on other sites More sharing options...
Notorious Posted November 23, 2018 Share Posted November 23, 2018 Would be for a 2006 OBXT that I'm buying from a family member in a little over a year. Make sure that this down pipe is for a LegacyGT/OBXT, WRX one’s will not fit without modification. Link to comment Share on other sites More sharing options...
AWDFTW Posted November 23, 2018 Author Share Posted November 23, 2018 Make sure that this down pipe is for a LegacyGT/OBXT, WRX one’s will not fit without modification. What kind of modification? Cobb's website lists the same part # for both, so I presumed it was a bolt in. Link to comment Share on other sites More sharing options...
cryo Posted November 23, 2018 Share Posted November 23, 2018 If your OBXT is manual trans all manual trans dp's for the 05-09 lgt and 08-14 wrx are the same...If its auto it changes the part number. Hope that helps Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
AWDFTW Posted November 23, 2018 Author Share Posted November 23, 2018 It is an auto. Thanks for the heads up. Link to comment Share on other sites More sharing options...
cryo Posted November 23, 2018 Share Posted November 23, 2018 yup, gonna need the auto dp as it makes contact with the trans without modification. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
