toy4rick Posted November 19, 2018 Share Posted November 19, 2018 Hey all, 2017 Legacy with Kardon sound system. When I select a HD radio station, it take 5-7 seconds to connect. Randomly and at specific spots around town the station will drop and it then takes 5-10 seconds to reconnect My dealer says the radio is running the latest software and that it's the HD radio service that is to blame Thoughts? Rick Link to comment Share on other sites More sharing options...
ncted Posted November 19, 2018 Share Posted November 19, 2018 Hey all, 2017 Legacy with Kardon sound system. When I select a HD radio station, it take 5-7 seconds to connect. Randomly and at specific spots around town the station will drop and it then takes 5-10 seconds to reconnect My dealer says the radio is running the latest software and that it's the HD radio service that is to blame Thoughts? Rick That is the experience I've had with every HD Radio I've ever owned. Subaru, Mazda, and Toyota head units all did this. In my discussions with other folks, the general consensus is it is the rolling hills and uneven terrain where I live. When I replaced the head unit in my wife's Forester, I didn't bother getting the HD Radio version. Also, HD Radio isn't "HD" per se. Sounds like a bad MP3 from Napster to me. Link to comment Share on other sites More sharing options...
larrya07 Posted November 19, 2018 Share Posted November 19, 2018 HD radio transmit at a much lower power than the main FM signal. The FM transmitter useally is 100K watts but the FCC limits the HD signal on the same channel to at most 10K watts. To make matters worse the HD signal is much more affected than the FM signal when your in the glass and brick canyons of cities. Link to comment Share on other sites More sharing options...
coldsoda Posted November 19, 2018 Share Posted November 19, 2018 normal for every car I've owned, including aftermarket head units from Alpine and Pioneer. I live kind of close to a regional airport and any time I get close to there the HD stations cut out, even though I'm in a big city. HD stations are great, but require a really good signal to work well. Link to comment Share on other sites More sharing options...
Yoda_One Posted November 19, 2018 Share Posted November 19, 2018 (edited) Like he said it is normal. When HD is lost it defaults to SD( standard FM). Laughing at oneself and with others is good for the Soul![emoji2] Edited November 19, 2018 by Yoda_One Laughing at Oneself and with Other is good for the Soul Link to comment Share on other sites More sharing options...
toy4rick Posted November 20, 2018 Author Share Posted November 20, 2018 In my case, when HD drops, I get dead air, no dropping back to Standard FM. And the other option for this station is AM... Oh well Thanks for the info Rick Link to comment Share on other sites More sharing options...
ncted Posted November 20, 2018 Share Posted November 20, 2018 In my case, when HD drops, I get dead air, no dropping back to Standard FM. And the other option for this station is AM... Oh well Thanks for the info Rick I have some stations that I get dead air on. Others will give me the analog broadcast, although it often isn't in sync with the digital broadcast, so it is really confusing, especially if I am listening to a sporting event. Link to comment Share on other sites More sharing options...
larrya07 Posted November 20, 2018 Share Posted November 20, 2018 (I have some stations that I get dead air on. Others will give me the analog broadcast, although it often isn't in sync with the digital broadcast, so it is really confusing, especially if I am listening to a sporting event.) When I was dealing with HD radio at the station I used to work for this was the biggest headache we had to deal with. To sync the analog to the digital signal you have to delay the analog signal by as much as two seconds and hope it doesn't change. Not sure about the dead air when HD goes away. The HD receiver must be still detecting the signal but unable to decode it. Link to comment Share on other sites More sharing options...
laufu Posted November 20, 2018 Share Posted November 20, 2018 (I have some stations that I get dead air on. Others will give me the analog broadcast, although it often isn't in sync with the digital broadcast, so it is really confusing, especially if I am listening to a sporting event.) When I was dealing with HD radio at the station I used to work for this was the biggest headache we had to deal with. To sync the analog to the digital signal you have to delay the analog signal by as much as two seconds and hope it doesn't change. Not sure about the dead air when HD goes away. The HD receiver must be still detecting the signal but unable to decode it. I think the dead air is because the radio is tuned to a sub channel. If the listener is listening to the primary channel and loses HD, it defaults back to analog radio. If it is a sub channel, the will be dead air. When the listener gets the HD signal back, there is about a 2 second delay for the radio to process the sub channel. It is annoying, but I have gotten use to it on my 13 Legacy. I am not sure about the 18/19 Legacy/Outbacks, but my Ascent, the radio never really turns off. I am guessing it is a bug in the software. The plus side to this it allows the radio time to tune into the HD and process the sub channels on startup so my HD sub channel is ready for me. Link to comment Share on other sites More sharing options...
ncted Posted November 20, 2018 Share Posted November 20, 2018 I think the dead air is because the radio is tuned to a sub channel. If the listener is listening to the primary channel and loses HD, it defaults back to analog radio. If it is a sub channel, the will be dead air. When the listener gets the HD signal back, there is about a 2 second delay for the radio to process the sub channel. It is annoying, but I have gotten use to it on my 13 Legacy. I am not sure about the 18/19 Legacy/Outbacks, but my Ascent, the radio never really turns off. I am guessing it is a bug in the software. The plus side to this it allows the radio time to tune into the HD and process the sub channels on startup so my HD sub channel is ready for me. Yes, the Legacy has the annoying, not-really-turning-off, radio. Link to comment Share on other sites More sharing options...
