relative4 Posted November 18, 2018 Share Posted November 18, 2018 I'm making plans to upgrade my turbo to a BNR 16G, and I will not be using the stock oil feed for that. I'm having trouble locating oil feed upgrade kits online. Can anyone make recommendations? Thanks! Link to comment Share on other sites More sharing options...
Code Posted November 18, 2018 Share Posted November 18, 2018 https://www.atpturbo.com/ Lots of good stuff here. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
kzr750r1 Posted November 18, 2018 Share Posted November 18, 2018 (edited) There was some heated back and forth on this subject a while back. Brian wants the feed to come from a sandwich plate off the filter. Specifically not the AVCS line as others have done... Me included, from a kit Mike was offering from Infamous Performance (RIP). After using the V1 10 micron kit, I jumped over to the 40 micron as he was provided with the V2 kits and kept rolling. Had to mill out a new bracket to mount it. Have not had an issue yet. Look up XRP for part number 704404FS40 for the filter. It's AN -4 fittings and then the rest is up to what Brian will warranty. My G16 still seems just fine with this setup tapped off of a double banjo bolt and the AVCS feed line. Clean it out every so often and have not seem much gunk come off of it each time I do clean it out. Edit: Brian is just calling out starvation as a root cause to not warranty a turbo. Edited November 19, 2018 by kzr750r1 Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 19, 2018 Share Posted November 19, 2018 Why won't you use the stock feed line? It's plenty large enough to feed the turbo and comes directly from the head. Putting a filter inline is also unnecessary. It's a great way to have a restriction in oil flow and cause the turbo to starve for oil. Standard oil feed line, standard oil feed line banjo bolt, Subaru banjo bolt filters all removed, live life happy. Link to comment Share on other sites More sharing options...
kzr750r1 Posted November 19, 2018 Share Posted November 19, 2018 ^This. Unless there are catastrophic issues and you change oil at proper intervals you should not have any issues. Main thing is to avoid the starvation attributed to the stock banjo bolt filter getting plugged due to improper OCI. Matter of fact in the long run I may pull my kit and go back to stock as well. Link to comment Share on other sites More sharing options...
relative4 Posted November 19, 2018 Author Share Posted November 19, 2018 Hm. OK, thanks guys. I'll take easy if it's good enough. Link to comment Share on other sites More sharing options...
kzr750r1 Posted November 19, 2018 Share Posted November 19, 2018 Just noticed your working with Dave at Cryotune... Good to bounce this off of him as well cause with the 16G your going to need a new tune. Link to comment Share on other sites More sharing options...
relative4 Posted November 19, 2018 Author Share Posted November 19, 2018 Just noticed your working with Dave at Cryotune... Good to bounce this off of him as well cause with the 16G your going to need a new tune. Thanks, already discussing hardware with him. Link to comment Share on other sites More sharing options...
DaveWaters Posted November 19, 2018 Share Posted November 19, 2018 https://legacygt.com/forums/showthread.php/bnr-16g-oil-supply-270957.html Link to comment Share on other sites More sharing options...
boomerz3580 Posted November 19, 2018 Share Posted November 19, 2018 I used the oil upgrade line kit from IAG on my BNR Sent from my SM-G960U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted November 19, 2018 Share Posted November 19, 2018 (edited) Have to agree, the stock oil feed with banjo filter removed works great. My vf52 has over 120,000 miles that way. Zero shaft play when I had the dp off last month. Edited November 19, 2018 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
kzr750r1 Posted November 19, 2018 Share Posted November 19, 2018 https://legacygt.com/forums/showthread.php/bnr-16g-oil-supply-270957.html Thanks for looking that up. The other dynamic in this is flow and addressed in this thread. I used the banjo bolt Brian sent with the Turbo... It has a much larger orifice than the stock VF40. But nothing states you cant use that new banjo bolt with the stock oil line. Now that were talking about it I may just pull the oil feed filter line and go back to stock. Next time I'm in there... Just need to find the parts in the horde. One hard line and one AVCS banjo bolt... Less clutter and maintenance. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 19, 2018 Share Posted November 19, 2018 (edited) There are a number of places to fit fittings and steel braid line to make up your own oil feed lines. I made just about all the oil and fuels lines on the race car back in the day. https://www.bing.com/search?q=earlshighperformancefittings&src=IE-SearchBox&FORM=IE11SR Here's a site we used to get a lot of items from, back about 2007 our car was in their catalog.https://behrents.com/ https://behrents.com/pc_combined_results.asp?pc_id=&search_keyword=&opts=&faceted_search_terms=Department~F6186A658EF94847B224145A3ECC32F4%7CCategories~C7C1A64C4BB84A21B8DF4903155ECC8B~322EEF194924433897591D8F02461647 Edited November 19, 2018 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
covertrussian Posted November 19, 2018 Share Posted November 19, 2018 I wouldn't reuse the stock line simply because they tend to crack and leak (especially if you have over 100k on them). Also stock lines have a restrictor built into the banjo bolt on the head side, which could starve a bigger turbo. I've been running this -4an SS line setup with my 16G for almost 25k miles: 05 LGT 16G 14psi 290whp/30mpg 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg Link to comment Share on other sites More sharing options...
relative4 Posted November 19, 2018 Author Share Posted November 19, 2018 Thanks covert & boomer for the options. Comments anyone on the IAG kit? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 19, 2018 Share Posted November 19, 2018 Not to be that guy but I still run the stock oil feed pipe 263,000 miles. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Gabo Posted November 19, 2018 Share Posted November 19, 2018 I wouldn't reuse the stock line simply because they tend to crack and leak (especially if you have over 100k on them). Also stock lines have a restrictor built into the banjo bolt on the head side, which could starve a bigger turbo. I've been running this -4an SS line setup with my 16G for almost 25k miles: Not to be that guy but I still run the stock oil feed pipe 263,000 miles. Max Capacity my stock feedline cracked so it is a possibility. There is no right or wrong answer regarding the feedline. That is to say ultimately it boils down to preference and budget. Budget ultimately seems to be the voice of "reason" when it comes to our hobby/cars. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 19, 2018 Share Posted November 19, 2018 (edited) I know anything is possible I just don't see how the stock pipe could crack. I know mine will not come apart at the joint, it is so rusted. This photo was taken May 2012. Edited November 19, 2018 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mondtster Posted November 19, 2018 Share Posted November 19, 2018 I know anything is possible I just don't see how the stock pipe could crack. I know mine will not come apart at the joint, it is so rusted. This photo was taken May 2012. It is my understanding that some of the oil feed lines did not have the stiffening bracket on them between the banjo bolt and the flare fitting. That could easily cause a crack at some point with the mass of that fitting hanging out there unsupported. I've seen it many times while doing vibration testing on engine components. That said, I see no reason to go away from the stock line, provided it has the bracket on it and the line is in good shape. Why reinvent the wheel? The line, or a suitable replacement needs to be left in place anyway to feed oil to the AVCS solenoid. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 19, 2018 Share Posted November 19, 2018 Mine has the support bracket. I have pictures of it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
kzr750r1 Posted November 22, 2018 Share Posted November 22, 2018 Thanks covert & boomer for the options. Comments anyone on the IAG kit?Looks like a clean option to replace both hard lines from the head. However you may want to put some thermal insulation over them. Not only for thermal protection but rub protection. Funny they are selling filtered banjo bolts as an option. Link to comment Share on other sites More sharing options...
