Sisco27 Posted November 13, 2018 Share Posted November 13, 2018 Hello, After a lot of time, my Subaru Outback 2.5i is lowered, with big brakes, new rims, with AVO Turbo Kit, new fuel pump and injectors, and a complete exhaust from the headers to the tips. As soon as I will finish it I promise a complete built thread! Now I am completely stopped, because I don't have any possibility to adjust ECU paramenters! My tuners says I need defs for this ECU, and at romraider nowbody answer to the threads about this ECU. Someone has experience about it? or someone recomends go to standalone ECU or Piggyback??? Please help me! Sisco Link to comment Share on other sites More sharing options...
Sparkey Posted November 13, 2018 Share Posted November 13, 2018 https://www.cryotuneperformance.com/faq Under "Software needed" it will have the links to the pages where you download the defs and such. As I understand it the Subaru ECU can do quite a bit - so unless you're 100% track car I wouldnt worry about standalone or piggybacks. 05' LGT, ZFD Built 5MT, Stage 2 Cryotune 91/E85, 170,000mi running BRotella T6 and Ecoguard S4615 filters. Link to comment Share on other sites More sharing options...
Sisco27 Posted November 14, 2018 Author Share Posted November 14, 2018 https://www.cryotuneperformance.com/faq Under "Software needed" it will have the links to the pages where you download the defs and such. As I understand it the Subaru ECU can do quite a bit - so unless you're 100% track car I wouldnt worry about standalone or piggybacks.Many thanks Sparkey! Unfortunatelly there are not defs for my ecu id / interna id. I don't know how to proceed... Enviat des del meu Redmi Pro usant Tapatalk Link to comment Share on other sites More sharing options...
Sparkey Posted November 14, 2018 Share Posted November 14, 2018 Many thanks Sparkey! Unfortunatelly there are not defs for my ecu id / interna id. I don't know how to proceed... Enviat des del meu Redmi Pro usant Tapatalk You're welcome. I think I understand your problem, but have no idea how to solve it or anything. I would reach out to a few other tuners (Cryotune, Tuning Alliance, Flatiorns, ect) Someone's bound to know something. The other option being getting in touch with heiche who created BtSsm (great for logging and such) and Perscitus who know a ton and I feel would be great people to lead you in the right direction. The BtSsm thread (https://legacygt.com/forums/showthread.php/btssm-bluetooth-adapter-app-v-2-267811p16.html) has tons of info as well as the archive as far as defs and things go. I dont know as much as I'd like to or should about that stuff, but I bet they relate. 05' LGT, ZFD Built 5MT, Stage 2 Cryotune 91/E85, 170,000mi running BRotella T6 and Ecoguard S4615 filters. Link to comment Share on other sites More sharing options...
Sisco27 Posted November 14, 2018 Author Share Posted November 14, 2018 You're welcome. I think I understand your problem, but have no idea how to solve it or anything. I would reach out to a few other tuners (Cryotune, Tuning Alliance, Flatiorns, ect) Someone's bound to know something. The other option being getting in touch with heiche who created BtSsm (great for logging and such) and Perscitus who know a ton and I feel would be great people to lead you in the right direction. The BtSsm thread (https://legacygt.com/forums/showthread.php/btssm-bluetooth-adapter-app-v-2-267811p16.html) has tons of info as well as the archive as far as defs and things go. I dont know as much as I'd like to or should about that stuff, but I bet they relate.Really thanks! Now it's time to read, read, and ask everybody to reach the solution! Enviat des del meu Redmi Pro usant Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted November 14, 2018 Share Posted November 14, 2018 Who’s the guy who tunes the super chargers on the 3.6R’s ? He may have some thoughts 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
moral hazard Posted November 14, 2018 Share Posted November 14, 2018 What's your ecu ID? Link to comment Share on other sites More sharing options...
Sisco27 Posted November 14, 2018 Author Share Posted November 14, 2018 What's your ecu ID? This is all the from the ECU Make: Subaru Model: Outback Submodel: 2.5i Market: USDM Transmission: MT Year: 07 ECU ID: 4B12187007 Internal ID: E2UE100C Flash Method: subarucan Memory Model: SH7058 Checksum Module: subarudbw Inherits: 32BITBASE Thanks for your help! Link to comment Share on other sites More sharing options...
moral hazard Posted November 14, 2018 Share Posted November 14, 2018 (edited) I will see if its possible to modify the definitions of E2UE102J to suit your ecuid. I've done similar before on my 2009 2.5i when I couldn't find a def. Might take a couple says to report back but I'll see what I can do. Edited November 14, 2018 by moral hazard Link to comment Share on other sites More sharing options...
Sisco27 Posted November 15, 2018 Author Share Posted November 15, 2018 I will see if its possible to modify the definitions of E2UE102J to suit your ecuid. I've done similar before on my 2009 2.5i when I couldn't find a def. Might take a couple says to report back but I'll see what I can do. WOW!! If you are able to do it you can solve my problem!!! Many, many Thanks!! Link to comment Share on other sites More sharing options...
Perscitus Posted November 16, 2018 Share Posted November 16, 2018 Should be fairly easy to build a definition, at least a skeleton of one with basic tables defined, and expand from there. Any luck getting td_d or dschultz help ($$$) over at RR forum? Post up the ROM (stock or tuned if ok to share) and the team here or there can fill in some blanks. Link to comment Share on other sites More sharing options...
Sisco27 Posted November 16, 2018 Author Share Posted November 16, 2018 Should be fairly easy to build a definition, at least a skeleton of one with basic tables defined, and expand from there. Any luck getting td_d or dschultz help ($$$) over at RR forum? Post up the ROM (stock or tuned if ok to share) and the team here or there can fill in some blanks.Hello! Thanks for your info! At RR forum nowbody answer me. I don't know the reason. Sisco Enviat des del meu Redmi Pro usant Tapatalk Link to comment Share on other sites More sharing options...
Sisco27 Posted November 17, 2018 Author Share Posted November 17, 2018 Should be fairly easy to build a definition, at least a skeleton of one with basic tables defined, and expand from there. Any luck getting td_d or dschultz help ($$$) over at RR forum? Post up the ROM (stock or tuned if ok to share) and the team here or there can fill in some blanks. Attached Link to my original ECU file E2UE100C https://drive.google.com/open?id=1JKkbrgYr1LQuCC4Vvp5ByE-hXz-zSyMn Thanks Link to comment Share on other sites More sharing options...
Sisco27 Posted November 18, 2018 Author Share Posted November 18, 2018 Perscitus I wait your info! Thanks Link to comment Share on other sites More sharing options...
Perscitus Posted November 19, 2018 Share Posted November 19, 2018 PM sent. The ECU is likely very similar to the 2007/8 USDM and other non-EDM region 2.5i - it might even inherit from their defs if any exist with some changes to memory addresses for tables, logger and RAM params. BtSsm should work out of the box with a BASIC profile alias. Link to comment Share on other sites More sharing options...
Sisco27 Posted November 20, 2018 Author Share Posted November 20, 2018 PM sent. The ECU is likely very similar to the 2007/8 USDM and other non-EDM region 2.5i - it might even inherit from their defs if any exist with some changes to memory addresses for tables, logger and RAM params. BtSsm should work out of the box with a BASIC profile alias. I hope I will have it next week! He answer me yesterday! Many thanks Perscitus! BtSsm will work too? Do you recomend me? Enviat des del meu Redmi Pro usant Tapatalk Link to comment Share on other sites More sharing options...
Perscitus Posted November 20, 2018 Share Posted November 20, 2018 Yup sure will. Link to comment Share on other sites More sharing options...
moral hazard Posted November 23, 2018 Share Posted November 23, 2018 (edited) I hope Perscitus has had some luck. My personal simple efforts using a hex editor did not work as they have in the past for me. It appears there are differences between your rom E2UE100C and the most similar ones I tried (E2UE102J, E2UE102L and E2UE102B). If Perscitus is unable to assist, my personal next step would be to flash E2UE102B onto your ECU and then work from there. Just ensure you try the 'test write' first and be prepared to recover via something like SH Boot Mode if it all fails. Edited November 23, 2018 by moral hazard Link to comment Share on other sites More sharing options...
gudmundur Posted January 20, 2019 Share Posted January 20, 2019 I hope I will have it next week! He answer me yesterday! Many thanks Perscitus! BtSsm will work too? Do you recomend me? Enviat des del meu Redmi Pro usant Tapatalk Did you ever get this to work or try to flash e2ue102b to your car ? regards Gudmundur Link to comment Share on other sites More sharing options...
