Musicteacher Posted November 13, 2018 Share Posted November 13, 2018 Thanks in advance, I had the HG changed out at 100000. currently 136000. In September the car overheated and thought it might be the HG again. My friend used a block tester and found no combustion gasses in the coolant. YEA. Bottom hose was cool to the touch so changed out the thermostat. Then the radiator tank gave up the ghost, changed that out. and the radiator cap. It over heated again today Nov 12 2018. Of course everything still indicates a HG but the coolant is not discolored, nice bright green. but it blew the cap off the collection tank and was bubbling. As I understand if there a HG problem the coolant color changes because of the combustion gasses. My question is could the thermostat that was suppose to fail open did and does not work and just did not open and it got hot a boiled over. Link to comment Share on other sites More sharing options...
Infosecdad Posted November 13, 2018 Share Posted November 13, 2018 Is it an OEM thermostat? Link to comment Share on other sites More sharing options...
Musicteacher Posted November 13, 2018 Author Share Posted November 13, 2018 It was a NAPA that was designed to fail open Link to comment Share on other sites More sharing options...
Infosecdad Posted November 13, 2018 Share Posted November 13, 2018 (edited) Historically Subaru’s really don’t like aftermarket thermostats or radiator caps. That a few of the parts that has to be OEM or has a decently high risk of failure. Edited November 13, 2018 by Infosecdad Link to comment Share on other sites More sharing options...
AWDFTW Posted November 13, 2018 Share Posted November 13, 2018 You want an OEM or Stant's XACTstat only. Also, I hope the headgaskets were a multi-layer steel design AND that the heads were checked and resurfaced if needed. Link to comment Share on other sites More sharing options...
Musicteacher Posted November 13, 2018 Author Share Posted November 13, 2018 (edited) The heads were ckecked and milled. the gasket was 26170pt Edited November 13, 2018 by Musicteacher Link to comment Share on other sites More sharing options...
AWDFTW Posted November 13, 2018 Share Posted November 13, 2018 That should be their MLS option. So...are your fans coming on correctly? What brand is the radiator cap? Suggest replacing NAPA stat with [parts listed above. Link to comment Share on other sites More sharing options...
kzr750r1 Posted November 13, 2018 Share Posted November 13, 2018 Well back up here... Was the waterpump replaced with the timing belt? Assuming were talking about a GT with a EJ255. New water pump and thermostat should have been part of the belt idler and tensioner maintenance. Link to comment Share on other sites More sharing options...
Musicteacher Posted November 13, 2018 Author Share Posted November 13, 2018 (edited) Miss read your question. Everything but the water pump was done at 100000. what are you thinking? thanks for asking all done at 100000 and auto trans flush back in 2015 when I was making money to have someone else do the work. Edited November 13, 2018 by Musicteacher Link to comment Share on other sites More sharing options...
Musicteacher Posted November 13, 2018 Author Share Posted November 13, 2018 That should be their MLS option. So...are your fans coming on correctly? What brand is the radiator cap? Suggest replacing NAPA stat with [parts listed above. just got a OEM thremostat The fans are coming on. So had to drive my car to work luckily it was 10 degrees above this morning. Top hose was 170 degrees and the bottom hose just 70 degrees. I measured this with a IR thermometer. Aftermarket thermostat is my problem. Now have an oem. Link to comment Share on other sites More sharing options...
kzr750r1 Posted November 13, 2018 Share Posted November 13, 2018 Ok. Just checking for clarity. Another thing is make sure you are using the "conditioner" if replacing the coolant. It's been widely debated here and general consensus is it is a preemptive stop leak product pushed by Subaru to help prevent head gasket failure. My choice after my rebuild was to put it in the system. Others disagree, everyone is entitled to their opinion. Choice is yours. I'm convinced the final need to to rebuild my motor was because of the silly decision to flush the cooling system with a prestone product. Hoping for you the OEM thermostat is going to keep you running. Let us know how it goes. Link to comment Share on other sites More sharing options...
Musicteacher Posted November 14, 2018 Author Share Posted November 14, 2018 Thanks to all from your advice. Did the block checker and it turned blue green. Had to first go with the hope that I could get away with a thermostat. But to know avail. thanks again Link to comment Share on other sites More sharing options...
rub2race Posted November 26, 2018 Share Posted November 26, 2018 Uuugh. Sorry to hear. never had any luck with a/m on a subi Link to comment Share on other sites More sharing options...
