The LEGACY GT 00 Posted November 7, 2018 Share Posted November 7, 2018 So I have a 2000 Subaru Legacy GT 2.5 no Turbo today and clean the map sensor but I accidentally disconnected and took off the throttle position sensor put it right back on then I cleaned out the idle control valve cuz it was sludged put it all back just connect to the battery put it all back then turn the car on start driving and my RPMs start shooting up I was high shifting car was shaking car was jolt in felt like the bottom was going to drop out need to know what happened what I do wrong now I have a check engine light Link to comment Share on other sites More sharing options...
RustyRuu Posted November 8, 2018 Share Posted November 8, 2018 what did you use to clean your map sensor? did you install the TPS to its original clocked location? Link to comment Share on other sites More sharing options...
RumbleRumble Posted November 9, 2018 Share Posted November 9, 2018 TPS has a idle switch in it. Not supposed to touch it. You need a multi-meter and adjust it until it has 5.1 volts and resistances are in spec. Look up the procedure its the same for most subarus until 2007 MAP sensor don't get dirty, MAF do. Link to comment Share on other sites More sharing options...
