Tehnation Posted November 4, 2018 Share Posted November 4, 2018 I was trying to figure out how I am going to mount the engine to the engine hoist, I want to be able to install and pull the complete engine. Is there a hoist mount that works for our engines? Couldn't find a specialized one just the generic leveler. If there isn't one, how do you guys hoist a complete engine? Link to comment Share on other sites More sharing options...
DaveWaters Posted November 4, 2018 Share Posted November 4, 2018 I used the cheap harbor freight leveler with some quick links. There’s a loop by the turbo on a bracket and diagonally across I used the a/c compressor bracket for the other point. It worked well. Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 4, 2018 Share Posted November 4, 2018 ^^^^This. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 4, 2018 Share Posted November 4, 2018 Do these help ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 4, 2018 Share Posted November 4, 2018 ^^^^ This. Link to comment Share on other sites More sharing options...
Tehnation Posted November 5, 2018 Author Share Posted November 5, 2018 Awesome! Yes! Do you have a picture of what the rear one attaches to? Link to comment Share on other sites More sharing options...
boxkita Posted November 5, 2018 Share Posted November 5, 2018 Put a bolt thru the the transmission mount. Use shoot on the turbo mount. Tie a "tie down" strap to any surface or around anything. Get the harbor freight ratcheting tie down kit. It has enough strength to hold it. In a pinch, you can use a single bolt on the front. Having done all of these , the HF crane with the leveler tied to the AC mount and the starter mount hole worked best. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
