JmP6889928 Posted November 3, 2018 Share Posted November 3, 2018 I NEED CORES! What does that tell you? If you have VF40/46/52 cores or even VF39/43/48 cores, I'm interested in them. Thanks for your patience everyone. I'm back on the mend and moving forward so I'll be around a bit more. Link to comment Share on other sites More sharing options...
ttnio Posted November 3, 2018 Share Posted November 3, 2018 copy that Jim! good times. Link to comment Share on other sites More sharing options...
shralp Posted November 4, 2018 Share Posted November 4, 2018 Got a buddy with a toasted VF52, I’ll let him know Link to comment Share on other sites More sharing options...
xVern Posted November 4, 2018 Share Posted November 4, 2018 Ooooh, Whats stock on 08s? I forgot already, but I gots one of them. Might actually just want you to make it good. Just paid off the leggy so im planning the future! Link to comment Share on other sites More sharing options...
Max Capacity Posted November 4, 2018 Share Posted November 4, 2018 Good to hear your back in the business. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Smithcraft Posted November 4, 2018 Share Posted November 4, 2018 I don't have a core, but I do have what should be a rebuildable VF46 that would like to get the wild treatment. (eventually!) SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
08SpecB_DE Posted November 4, 2018 Share Posted November 4, 2018 I could use a refreshed vf46. No shaft play with 117k but I'd like to replace it before it grenades. It's my DD so I have very little down time to play with. Can you PM me pricing options? Thank you! Link to comment Share on other sites More sharing options...
mondtster Posted November 5, 2018 Share Posted November 5, 2018 I’ve got a vf40 that I don’t need anymore Link to comment Share on other sites More sharing options...
relative4 Posted November 5, 2018 Share Posted November 5, 2018 Great news! Welcome back! Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted November 7, 2018 Share Posted November 7, 2018 Welcome back! I was hoping I would be able to use your services when I get my rebuild going. 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
Gabo Posted November 7, 2018 Share Posted November 7, 2018 I got a VF40 that was in working order when replaced with the V52. Let me know Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 7, 2018 Author Share Posted November 7, 2018 Everyone with cores, please PM me and let's see what we can work out. As always, I remember people who help me when they need help, so thanks much in advance. Link to comment Share on other sites More sharing options...
Gabo Posted November 7, 2018 Share Posted November 7, 2018 Pm'ing you now Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted November 7, 2018 Share Posted November 7, 2018 Everyone with cores, please PM me and let's see what we can work out. As always, I remember people who help me when they need help, so thanks much in advance. I'll see if I can grab my old vf46 back out of my buddies shop, it's just sitting on the shelf there 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 18, 2018 Author Share Posted November 18, 2018 Guys, I have enough parts on hand to actually build 3 complete turbos right now. I have 2 OE Style VF40 I'll be building and one Custom VF46. I'll be working on these in the next few days. Any and all cores will be greatly appreciated. Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 26, 2018 Author Share Posted November 26, 2018 Decided to visit some of my archived stuff today. I've had these parts in a box for the better part of 4 years now as I had abandoned the bearing plan. As far as I know, this is the only roller bearing VF40 turbo center section on the planet. I had the parts for this with the custom machined center bearing support housing and the roller bearings I had purchased to build a couple of prototypes, so I went ahead and assembled it tonight. Originally, my idea was to run quad ball bearings as in the photo in the next post, and I'm sure that idea would work as I had a prototype up and running for a little bit, I think the roller bearing idea is far more robust than the 4 ball bearing design would be. This particular center section also has larger than stock VF40 forged billet custom wheel on it. I will probably finish it and try it on my own car in the early spring just to see what it does. The wheel is between a VF40 and VF52 in size, so it might just be a perfect combination for spool and upper RPM pull. I won't ever build another with this size wheel as it was extremely labor intensive to make the compressor housing match up to the wheel (back when I had access to the tools needed), but if the center itself with the roller bearings turns out to be viable, I may pursue it again utilizing my normal Custom VF40/46 forged billet wheel and see where it leads me. I have a new potential machine shop that just may work out. Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 26, 2018 Author Share Posted November 26, 2018 (edited) This was my original idea and I might just revisit it too. I do believe the roller bearings will be more solid, but they do have more friction due to the width of the rollers versus the ball bearings. On the left is what is currently inside of a VF40/46 turbo with journal bearings and the spacer. On the right was my quad bearing idea and it lined up perfectly with the oil feed to push the oil between the two bearings on each end. It has worked already for me as I had one on my own car for a short time. Time will tell. Edited November 26, 2018 by JmP6889928 Link to comment Share on other sites More sharing options...
CrowNaza86 Posted December 13, 2018 Share Posted December 13, 2018 Hmm, good timing, John. I'm thinking it is a good idea to replace the VF-46 in my '09. It has 104K on it right now, but is in great shape. PM me some info please! Link to comment Share on other sites More sharing options...
tfro33 Posted December 29, 2018 Share Posted December 29, 2018 bumped your old thread about cores by mistake, glad i saw this one though. also sent pm Link to comment Share on other sites More sharing options...
gkinslow Posted January 3, 2019 Share Posted January 3, 2019 https://legacygt.com/forums/showthread.php/detroit-mi-oem-clutch-kit-snow-tires-wheels-vf-40-277003.html Potential core in the classifieds. Link to comment Share on other sites More sharing options...
