seiyafan Posted November 2, 2018 Share Posted November 2, 2018 Last evening I started the car and the low oil light came on, turned the key off after about 5 seconds, checked dipstick and the level was 1/8'' below the low mark. Then I drove about 8 miles to home and waited for the engine to cool for about an hour, checked the dipstick again and it was almost at the full mark (similar to the level that I checked last month). While still confused I reset the low oil light. Does this indicate something's wrong with the oil pump? The car drove fine without any noise from the engine. Link to comment Share on other sites More sharing options...
Shadow_419 Posted November 2, 2018 Share Posted November 2, 2018 Yellow oil level light or red oil pressure light? Could just be the sensor is failing. Link to comment Share on other sites More sharing options...
seiyafan Posted November 2, 2018 Author Share Posted November 2, 2018 The yellow one. My only concern is the possibility of a pump failure. Link to comment Share on other sites More sharing options...
Shadow_419 Posted November 2, 2018 Share Posted November 2, 2018 Pump failure would definitely put oil pressure at risk. I wouldn't be too worried about pump failure if the level seems fine. I'd start with the oil level sensor as a culprit. Link to comment Share on other sites More sharing options...
seiyafan Posted November 2, 2018 Author Share Posted November 2, 2018 For now I will drive as normal, but will take it to a shop if the light comes on again. Link to comment Share on other sites More sharing options...
hallowground Posted November 5, 2018 Share Posted November 5, 2018 I know my 3.6r has the oil light come on when I take very short drives and it does not heat up to operating temp. If I drive only a mile and stop my car the next time I drive it usually the light comes on. Still has oil full and everything. I never really looked into why it would do it however mine might burn a quart every 2.5k Sent from my SM-G935V using Tapatalk Link to comment Share on other sites More sharing options...
NVAKeith Posted November 5, 2018 Share Posted November 5, 2018 (edited) Check the manual. After topping off oil, you have to drive for a mile or so with the car warmed up for the low oil level light to turn off. My light came on once when parked in a steep hill, I freaked out when it didn’t turn off after driving a block. Edited November 5, 2018 by NVAKeith Link to comment Share on other sites More sharing options...
seiyafan Posted November 5, 2018 Author Share Posted November 5, 2018 I did, in fact I drove 8 miles with the light on and it didn't turn off at the end. I had to reset it using the fuse method, so glad I actually found it. Link to comment Share on other sites More sharing options...
