BE fuel gauge/cluster issues
I just recently bought a BE sedan and it came with three speedos. The one it came with was a high milage replacement for the original that had a fuel gauge issue and was in temporarily while being fixed. I tried fitting the original fixed one in and there is still a fuel gauge issue it doesn't read properly at all, I tried taking the needle off the high mileage gauge and putting it on the third lower mileage speedo and that didn't work now I've put the needle back on the high mileage one and now that won't work either!
So do I just need to buy a replacement cluster?
maybe its the fuel sender and not the gauge..
Gauge was working perfectly with the higher mileage gauge, I've notice speedo and temp gauge are also reading higher then they are suppose to so its definitely the gauge. I'll just have to replace it
