96 Legacy: Is this the idle air control valve?
That looks like throttle position sensor. Looks like the IACV is the thing to the right with ABC on it. It will have a fairly large hose going to the intake about half way to the air filter box. IACV is basically a controlled leak of air past the throttle plate.
There is a procedure to put that TPS back on because of the slotted mounting holes. If it isn't calibrated the computer will be a little bit confused.
