Rednik Posted October 14, 2018 Share Posted October 14, 2018 Hi everyone, I'm a noobie so this might be a dumb question... My carrier bearing needs replacement and I was wondering if I could replace is separately or if I will need a replacement driveshaft. I have an 01 GT wagon and my uncle has an 03 outback sitting in his yard so I was going to try and take the carrier bearing out of that if possible. Any help is greatly appreciated Thank you Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted October 14, 2018 Share Posted October 14, 2018 Different propeller shafts, the Outback's is taller. OEM shaft is the best option. If you have a local driveshaft shop, they may be able to make a one piece shaft if you give them your old one to copy. This thread will have a link to a couple places that may help. https://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted October 14, 2018 Share Posted October 14, 2018 I just googled it. https://www.google.com/search?q=2001+subaru+legacy+gt+wagon+propeller+shaft&oq=2001+subaru+legacy+gt+wagon+propeller+shaft&aqs=chrome..69i57.26532j0j8&sourceid=chrome&ie=UTF-8 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Rednik Posted October 14, 2018 Author Share Posted October 14, 2018 Thanks, Don't think I'll be needing a new one since this happened :/ Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted October 15, 2018 Share Posted October 15, 2018 Sorry to see that. Hey, junk yard hatch and bumper cover...and you could be on your way. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
