WRX SWAP Help
Hi Guys,
So I have a 2005 Legacy GT, It has some problems that I am working on getting parts to fix.
What I was wondering is if someone could tell me what will I be able to bolt on to my legacy from a 2008+ WRX?
I know the transmission and rear dif I can use as well as the engine (obvs) but what about suspension stuff? Also, If i were to put a transmission and rear diff in from a wrx, would I need any custom parts made or would my current axles and driveshaft bolt on to them. same with the transmission mount.
also, any other parts that would fit onto the car would be good to know.
Thanks
I think we assume your using your intake manifold and wire harness. I'm sure the short blocks are the same.
I think there is another thread yesterday asking the same type question, using a 08 in a 05.
Engine Build - Click Here
