Mr.RMFC Posted October 3, 2018 Share Posted October 3, 2018 Ok, so ive read a bunch of the different misfire threads but could not find one that matched with what im seeing. So I am getting a cylinder 3 misfire (I have an accesport to read the code) with the rough idle. This only happens when at idle or low speed as I can clear the code and drive on the highway if needed. It does have the flashing cruise light so I drive it as little as possible as I have a diagnosis scheduled at a shop. What I have done so far. 1. Replaced coil pack 2. Swapped injectors with cylinder 1 3. Cleaned the spark plug when it was out (Did not seem fouled) 4. Ran Seafoam through the fuel 5. Ran Octane Booster through the system What I found interesting was that, when I ran the seafoam through the system, it seemed to help for about 2 hours of normal driving as it made the idle a lot smoother and super small misfires a lot farther apart. after that 2 hours, it returned to normal roughness and threw the code. A similar thing happened with the Octane Booster but it went smoother than the seafoam but for a shorter amount of time. I have also run fuel from different stations to experiment with that with basically no difference. I have it scheduled at the local dealership as no one local can do a full diagnosis (nearest "Subaru" performance shop is 176 miles away) Figured I would post on here to see what people are thinking side note: The SeaFoam really reduced the valve noise which was nice Link to comment Share on other sites More sharing options...
relative4 Posted October 3, 2018 Share Posted October 3, 2018 Have you swapped the spark plug with cylinder 1? A worn coil pack connector is a possibility. A tiny twist on the pins with needle-nose pliers may help. Compression test is next. Link to comment Share on other sites More sharing options...
moral hazard Posted October 3, 2018 Share Posted October 3, 2018 Have you checked for a vac leak? Link to comment Share on other sites More sharing options...
