youngtryhard Posted October 1, 2018 Share Posted October 1, 2018 Can anyone tell me how or direct me to a link that has full instructions on how to remove the intake manifold with the fuel lines and TGV’s thank you. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 1, 2018 Share Posted October 1, 2018 Pretty straight forward if you open the hood look things over and make a plan. Relief fuel pressure Drain some coolant Take fuel lines off at the shock tower Remove bolts at heads Look for other things and remove as needed 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
