need clutch advice
I recently bought a Stage 2 Action Clutch because my throwout bearing completely failed. I got the Action Clutch in the mail and when I put the clutch right on the transmission to test fit, it is a bit loose. There is some play in it. if I hold the snout, i can wobble the clutch a little bit.. is this normal or should i call and try to return/swap for another?
Should be very little movement of the clutch disc on the spline from the tranny. The input shaft will have play in it as well.
I have never noticed any movement but then I have never worried about it. I do test fit but never really wiggled it around.
I suggest you put a light coat of high temp grease on the splines as well as the snout on the tranny where the TOB slides. Oh yea grease the ID of the pilot bearing too. Anti-seize compound on all bolt and nut threads.
Engine Build - Click Here
That's seems to be more then I recall. It has been a while since I've checked...
Ask action clutch, send it to them, or the email I gave you.
Edited by Max Capacity
