suprunner Posted September 7, 2018 Share Posted September 7, 2018 Hi all, first time posting here. I have done some searching with the above transmission code, and through posts referencing that year/model 5mt... Haven't found exactly my answer. If anybody does, I'm happy to read more... ANYWAY, I'm about to purchase a 5mt with under 60k miles on it. Code: TY757VBAAB . I believe this came with the '05 Legacy GT wagon... I only have pictures of this thing right now, and it appears that there is not a speedometer sensor, but a plug where one would go. Just curious if there will be a pickup gear under, or will I need to split the case and install? Going into a '98 Outback with a "Frankenmotor" (2.5 SOHC block with 2.5 DOHC heads). Thanks for your time, Greg Link to comment Share on other sites More sharing options...
Andy_Mac Posted September 7, 2018 Share Posted September 7, 2018 Not exactly sure what is present in the box, but The 4th gen manuals used ABS speed sensors for speedo readings so didn't use any kind of transmission mounted solution so you’d assume Subaru wouldn't install one and just not use it 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
suprunner Posted September 7, 2018 Author Share Posted September 7, 2018 Not exactly sure what is present in the box, but The 4th gen manuals used ABS speed sensors for speedo readings so didn't use any kind of transmission mounted solution so you’d assume Subaru wouldn't install one and just not use it Okay, that makes sense. Looks like I’ll be installing one. Link to comment Share on other sites More sharing options...
