lmm0611 Posted September 4, 2018 Share Posted September 4, 2018 I have 1998 Legacy gt and it had a key fob at one point, I'm looking for a replacement key fob or an oem key fob. I have looked for them but I'm not sure if I'm looking at the right ones, can any one help. Thanks. Link to comment Share on other sites More sharing options...
KartRacerBoy Posted September 4, 2018 Share Posted September 4, 2018 Sears. Link to comment Share on other sites More sharing options...
lmm0611 Posted September 4, 2018 Author Share Posted September 4, 2018 I'm going to need a little bit more info than just sears. Link to comment Share on other sites More sharing options...
KartRacerBoy Posted September 4, 2018 Share Posted September 4, 2018 It's store that sells key fobs. You're on a computer. You don't need more information than that. Go for it. Link to comment Share on other sites More sharing options...
twisty Posted September 6, 2018 Share Posted September 6, 2018 actually, the "more info" he may need is to get the fcc ID number off the back, do a search and make sure he gets one that matches so it will be able to be programmed into his existing system. Link to comment Share on other sites More sharing options...
KartRacerBoy Posted September 6, 2018 Share Posted September 6, 2018 Or you can go to the store, see what cars the fobs work for, and buy the one that works. That's what I did. Link to comment Share on other sites More sharing options...
Setnev Posted September 7, 2018 Share Posted September 7, 2018 You need the Code Alarm remotes for >98 models, model GOH-M24, like this one. https://www.ebay.com/itm/332518388285 Then follow the instructions for Code Alarm System here: http://www.cars101.com/subaru/keyless.html Link to comment Share on other sites More sharing options...
Stevo F Posted September 9, 2018 Share Posted September 9, 2018 You need the Code Alarm remotes for >98 models, model GOH-M24, like this one. https://www.ebay.com/itm/332518388285 Then follow the instructions for Code Alarm System here: http://www.cars101.com/subaru/keyless.html This is exactly what I did for our '98 GT. Just get any GOH-M24 fob from Ebay (doesn't need to be Subaru, I got one from a Mopar, but it's the same remote). Follow the instructions- super easy to set up to work with your car. Link to comment Share on other sites More sharing options...
FiveZigen Posted September 10, 2018 Share Posted September 10, 2018 You can sometimes find them at your local auto wrecker. I have picked up a couple of them over the years and grab them anytime I see them. They are easy to reprogram or add additional fobs. Link to comment Share on other sites More sharing options...
