gregrock1989 Posted August 28, 2018 Share Posted August 28, 2018 I'm sure this has been covered before and I'm sorry but I keep finding different information on this and would really like some confirmation. First of all, how many banjo bolts are in the 05 XT? I keep reading that theres 3 but I've been told (and shown) by a guy on a FB group that there are 4. One by the turbo, one behind the timing belt cover, and 2 ontop of the heads on the driver and passenger sides. So it is actually 4 in total am I right? Second, I understand the banjo bolt size for the one by the turbo is different from the others, but is the copper washers used for all 4 bolts the same? (part number 803912040) And lastly can someone confirm that the torque spec is 21.4 ft lbs when they go back in? Just bought an 05 xt. Previous owner said he removed the screens from the turbo banjo bolt and the one behind the timing cover, but he wasn't aware of the (2?) ontop of the heads. So I'll be removing those next oil change, anything else I'll need to know before attempting this would be appreciated. Link to comment Share on other sites More sharing options...
rhino6303 Posted August 28, 2018 Share Posted August 28, 2018 There are 5 total oil feed banjos, 2 for each avcs feed line and then 1 on your turbo for the oil feed. Additionally, there are 3 total coolant banjos, 1 at the back of the head to feed the turbo and then 2 on the turbo. Torque specs: 4 avcs oil feed banjos: 21.4 ft-lbs 1 turbo oil feed on turbo: 11.6 ft-lbs 2 turbo coolant feeds on turbo: 24.6 ft-lbs 1 coolant tank feed on cylinder head: 24.6 ft-lbs Link to comment Share on other sites More sharing options...
gregrock1989 Posted August 28, 2018 Author Share Posted August 28, 2018 Okay thanks. So they all use the same crush washers? Link to comment Share on other sites More sharing options...
rhino6303 Posted August 29, 2018 Share Posted August 29, 2018 Okay thanks. So they all use the same crush washers?Yes. All except for the turbo oil feed on the turbo (as you alteady stated). Link to comment Share on other sites More sharing options...
gregrock1989 Posted August 29, 2018 Author Share Posted August 29, 2018 803912040 is the correct ones to use on the avcs lines? Link to comment Share on other sites More sharing options...
rhino6303 Posted August 30, 2018 Share Posted August 30, 2018 803912040 is the correct ones to use on the avcs lines?Those are the correct washers, yes. Do yourself a favor though; buy a bag of generic m12 crush washers off of amazon. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 30, 2018 Share Posted August 30, 2018 This may help, I bookmarked this as a favorite. https://forums.nasioc.com/forums/showthread.php?t=2834394 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
