Boulderguy Posted August 24, 2018 Share Posted August 24, 2018 I know, generic question but I'm a turbo neophyte '05 OXT at 92k miles, original owner, original turbo, zero engine mods. The last few days the turbo has felt weak. Checked my boost gauge under WOT tonite, it usually reads around 15psi, now only showing 11psi. It was 73° out. Wondering if it's time to check the turbo for replacement. No CEL's or any other problems. For those more experienced, what would you do? Link to comment Share on other sites More sharing options...
relative4 Posted August 24, 2018 Share Posted August 24, 2018 Check fuel trims, check for boost leaks Link to comment Share on other sites More sharing options...
Boulderguy Posted August 24, 2018 Author Share Posted August 24, 2018 Thanks. Work with me on the terms - boost leaks at plumbing joints for example? Fuel trims meaning fuel mixture like pump or injectors? Link to comment Share on other sites More sharing options...
relative4 Posted August 24, 2018 Share Posted August 24, 2018 http://www.turboboostleaktesters.com Google BtSsm learning view If you can make it down to the tech center, I can do this testing for free. Or look up traildogck here or at subaruoutback.org, he's closer. Link to comment Share on other sites More sharing options...
JF1GG29 Posted August 24, 2018 Share Posted August 24, 2018 When the turbo on my WRX started going, it wouldn't hit boost targets. It very slowly got worse, and then it started making crazy noise as the blades contacted the housing. Link to comment Share on other sites More sharing options...
Boulderguy Posted August 24, 2018 Author Share Posted August 24, 2018 Thanks, I may take you up on this. Link to comment Share on other sites More sharing options...
