amp583 Posted August 13, 2018 Share Posted August 13, 2018 Folks, having a bit of transmission woes with my 2008 LGT 5EAT In October 2017 I changed my VB. I had a Turbine Speed Sensor 2 error code. I performed the TCU reset successfully using VAG COM cable, etc. Ever since my VB swap, I still have a slight kick in shifting down and up. Noticeable when the throttled is aggressively engaged or pulled off of. I can manage avoiding the kick by less steep throttle. No ECU or TCU lights, as of yet. Before I flush fluid, etc. wanted to get thoughts from the community on possible issues. Any ideas? Link to comment Share on other sites More sharing options...
m sprank Posted August 14, 2018 Share Posted August 14, 2018 Afaik the vag com cable and software can not reset tcm learning. I use a 5k+ scanner for that. If you really have an 08 a vag com cable does not even work with the car. You would need a tactrix and my first statement still applies. Link to comment Share on other sites More sharing options...
