m sprank Posted August 10, 2018 Share Posted August 10, 2018 Originally posted in 2012. Re-posting here for easier member searching. I get asked to explain it all the time. So, rather than write it I will show it. Subarus are notorious for the TOB wearing out before the clutch. When the TOB wears it rides on the snout in a non-perpendicular angle, causing major wear. This can be remedied with a TSK-3 kit if caught early. When you push it, you get to buy a new tranny. This tranny is a LGT 05 5MT wagon. TOB is in so many pieces I can not count. Two remaining pieces on the shaft are seized. I can not get them off without causing more damage. If you hear it, feel it, or suspect it. Might be time to check/replace it. Link to comment Share on other sites More sharing options...
