Skyboss-alpha1 Posted July 18, 2018 Author Share Posted July 18, 2018 So I had the car repaired, but now the car has started consuming oil like crazy oddly I don't see a leak and the car is not blowing smoke. So where's the oil disappearing to? What would cause the vehicle to consume so much oil, I literally just put a quart in 3 days ago and now the low light engine oil is back on. Link to comment Share on other sites More sharing options...
Sarang Posted July 18, 2018 Share Posted July 18, 2018 What did they do to repair it? If you can't find a leak it's likely being burned up in the combustion chamber, which is not great. Link to comment Share on other sites More sharing options...
Skyboss-alpha1 Posted July 18, 2018 Author Share Posted July 18, 2018 According to them resurface heads and head gasket and o rings Link to comment Share on other sites More sharing options...
Infosecdad Posted July 18, 2018 Share Posted July 18, 2018 How long since the repair? Low oil light is 2 qts low I think, if you add a quart you still won't be registering on the dip stick. If you are burning oil that fast and this only started after the repair; probably need to take it back to them and ask them to address. Link to comment Share on other sites More sharing options...
