fastcar123 Posted May 31, 2018 Share Posted May 31, 2018 Hello, I would like to mod my headlights with some new c lights, a Halo, and possibly some new projectors. I am very good at figuring stuff out but this one is something I want to be sure on. Is there a docent or thread with deatiled disassbly instructions and proper measurements taken for the halos and projectors? I am confident that I could do it but again I want to be sure. If there isn't a document like this already I would like for someone with a bit more experience to make one. I am also on the fence on weather I want to buy new / used headlights on eBay or just use what I've got. But I think I'll buy new one unless the process is just that easy. Thanks in advance! Link to comment Share on other sites More sharing options...
ammcinnis Posted May 31, 2018 Share Posted May 31, 2018 What problem(s) are you trying to solve? "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
ScoobaruSpud Posted May 31, 2018 Share Posted May 31, 2018 Good videos on Youtube - watch them all. And especially be careful with that oven... Link to comment Share on other sites More sharing options...
PATS4LIFE Posted May 31, 2018 Share Posted May 31, 2018 Hello, I would like to mod my headlights with some new c lights, a Halo, and possibly some new projectors. I am very good at figuring stuff out but this one is something I want to be sure on. Is there a docent or thread with deatiled disassbly instructions and proper measurements taken for the halos and projectors? I am confident that I could do it but again I want to be sure. If there isn't a document like this already I would like for someone with a bit more experience to make one. I am also on the fence on weather I want to buy new / used headlights on eBay or just use what I've got. But I think I'll buy new one unless the process is just that easy. Thanks in advance! You can do this with 3options for opening it Oven(better have a good size oven for headlights to fit) Set temp about 220 and when its ready put headlights in but use a wood to place headlight on,but before putting headlight in oven make sure to remove all screws including adjster screw anything metal. Leave headlight in for 5-10min constanly checking and try and pry it open with a flat screw driver,if the glue is still hard then leave in the oven for a few more mins then try again..you can searh in yourube theres plenty of videos. 2)you can use a heat gun but it takes longer. 3) tou can cur it open using dremel or soldering iron with a cutting blade in it. As for halos you need a 90mm size and get youself a beading wire (28 or 32guage steel)tou can also search on yourube for install on using wire. Link to comment Share on other sites More sharing options...
PATS4LIFE Posted May 31, 2018 Share Posted May 31, 2018 Also when your opening the headlight be very careful or youll end up breaking the blinker reflector,but since your going with new C-lignts then you rwally need that reflector.. Link to comment Share on other sites More sharing options...
PATS4LIFE Posted May 31, 2018 Share Posted May 31, 2018 Hello, I would like to mod my headlights with some new c lights, a Halo, and possibly some new projectors. I am very good at figuring stuff out but this one is something I want to be sure on. Is there a docent or thread with deatiled disassbly instructions and proper measurements taken for the halos and projectors? I am confident that I could do it but again I want to be sure. If there isn't a document like this already I would like for someone with a bit more experience to make one. I am also on the fence on weather I want to buy new / used headlights on eBay or just use what I've got. But I think I'll buy new one unless the process is just that easy. Thanks in advance! I would gor the RX350 with clear lens https://legacygt.com/forums/showthread.php/im2c0ols-15-cwp-legacy-ltd-ride-journal-lots-pictures-229871p11.html?highlight=im2c0ol+retrofit Link to comment Share on other sites More sharing options...
upstater Posted May 31, 2018 Share Posted May 31, 2018 go to NASIOC and look at the light mod threads : https://forums.nasioc.com/forums/showthread.php?t=2620784&page=111 I have posts there, you need to search for what you need, I did an HID and C-Light retrofit and used https://www.theretrofitsource.com/projector-kits/hid-led-projectors/bi-xenon-morimoto-mini-d2s-4-0-projectors.html Link to comment Share on other sites More sharing options...
