jrgene16 Posted May 26, 2018 Share Posted May 26, 2018 Hi there, i would like to ask some help regarding with my subaru problem. My car atf flashing continously. It happen yesterday when i drove my car, went to park, reverse it and suddendly my engine turns off. When i start again the car, atf light started to blink continuously. However it stop blinking when i turn off the car and turn it back on again. I tried to pull a code in obd but no code shows. Help me to diagnose. My initial thinking is atf oil temperature sensor. Any taught pls help thank you Link to comment Share on other sites More sharing options...
RumbleRumble Posted May 26, 2018 Share Posted May 26, 2018 Check too see if your low on ATF. Find the leak if it is low. Link to comment Share on other sites More sharing options...
