pjcampbell Posted May 25, 2018 Share Posted May 25, 2018 I have a 2005 Legacy Outback and I am trying to figure out where on earth to run wires in from engine bay for oil pressure sender and AFR (AFR doesn't necessarily need to come in from the engine bay). Can anyone help? The location is cubby replacement for dual gauge pod from Ortiz. I have been pointed to 2 tiny holes on either side of the pitch stop. I can't figure out where they come in on the inside. They are too small and would have to be drilled wider. There is 1 huge rubber hole plugged high up on the passenger side but I also can't figure out where it comes in on the inside. If I start taking apart the cover by the windshield wipers I might be able to figure it out. Is there an easier option? Link to comment Share on other sites More sharing options...
pjcampbell Posted May 25, 2018 Author Share Posted May 25, 2018 I think I'm good. I went through the AC drain hose plug. Link to comment Share on other sites More sharing options...
