Jameson Posted May 24, 2018 Share Posted May 24, 2018 I’ve got some noob questions that hopefully you guys can answer. The past couple days my wagon has been performing poorly, in lower RPMs like anything before 2400 the car has trouble accelerating and feels hesitant to accelerate. The car is fine after 2400 RPMs and runs as smooth as can be. I’ve replaced the fuel filter and am currently waiting on the MSD coil pack to come in so I can put my plugs and wires on along with that. Do you guys think it could be my MAF? And would you suggest either cleaning it or just buying a new one Link to comment Share on other sites More sharing options...
Brighton96 Posted May 24, 2018 Share Posted May 24, 2018 I'd check the air filter and replace it if necessary and then I'd clean the MAF and throttle body and I'd pull all the electrical connections you can find and spray them out with electrical cleaner. Link to comment Share on other sites More sharing options...
doublechaz Posted May 25, 2018 Share Posted May 25, 2018 Did this problem fade in or happen all at once? Link to comment Share on other sites More sharing options...
Jameson Posted May 26, 2018 Author Share Posted May 26, 2018 Did this problem fade in or happen all at once? One day it just started happening, it only happens every now and then. Sometimes worse than others, I changed the air when I got the car around two months ago. Link to comment Share on other sites More sharing options...
Setnev Posted May 27, 2018 Share Posted May 27, 2018 Don't buy a new MAF, clean it with MAF cleaner. Let's start with the basics. You're about to change the coil, plugs, and wires. Change those, see if the issue goes away. Mine used to hesitate during cold damp mornings and it turned out to be the diaphragm on the EGR valve. Link to comment Share on other sites More sharing options...
Jameson Posted May 27, 2018 Author Share Posted May 27, 2018 Don't buy a new MAF, clean it with MAF cleaner. Let's start with the basics. You're about to change the coil, plugs, and wires. Change those, see if the issue goes away. Mine used to hesitate during cold damp mornings and it turned out to be the diaphragm on the EGR valve. Thanks for the advice, I’ll keep you guys updated once the coil pack comes in Link to comment Share on other sites More sharing options...
