Dalee1104 Posted May 15, 2018 Share Posted May 15, 2018 Hey guys been while since I've talked to most of you. I ended up selling me 2nd gen and got a 08 spec b so I've been lurking around the 4th gen forums a lot. Anyways I have a question for some of you guys about engines. My brother is looking to get a subaru and I just found a 98 impreza, 2.2, 5 speed, going for 1000 bucks because the timing jumped. Now if im not mistaken the 2.2 in that car is the same 2.2 found in the later legacys. If the timing has jumped aren't those engine a non interference? Is it even worth going for to try and fix up and drive reliably? It's been sitting for 2 years Link to comment Share on other sites More sharing options...
Brighton96 Posted May 15, 2018 Share Posted May 15, 2018 That 2.2 is phase 2 which means it is interference I believe, so while the motor may spin freely, I wouldn't try to start it until either after pulling the motor and doing an inspection or resetting timing and doing a compression test. Link to comment Share on other sites More sharing options...
Dalee1104 Posted May 15, 2018 Author Share Posted May 15, 2018 So probably a no go for the little brother huh. He's not entirely too inclined in mechanics and I've been too busy to take up a project Link to comment Share on other sites More sharing options...
