t0lkman Posted May 11, 2018 Share Posted May 11, 2018 What the best way to fix the paint on the roof, see photos Link to comment Share on other sites More sharing options...
FLlegacy Posted May 12, 2018 Share Posted May 12, 2018 I have seen members merely recoat them with spray paint, plastidip them, and wrap them in vinyl. I think for these pieces vinyl will last the longest. Link to comment Share on other sites More sharing options...
t0lkman Posted May 12, 2018 Author Share Posted May 12, 2018 Can I remove them or just paint in place? Link to comment Share on other sites More sharing options...
FLlegacy Posted May 12, 2018 Share Posted May 12, 2018 It is apparently not meant to be removed, as the repair manual shows a rivet holding in the front piece. I would leave it in place...one more reason to use the vinyl in my opinion. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted May 12, 2018 Share Posted May 12, 2018 I would remove it and replace it... or repaint it with something more durable the problem with painting it in place is you are going to have a edge between painted and not painted parts and it will peel again.. Link to comment Share on other sites More sharing options...
DrD123 Posted May 12, 2018 Share Posted May 12, 2018 Can I remove them or just paint in place? Removing and refinishing is probably the way to go - they are held in place with six clips and a push in rivet - so no pulling the headliner or anything like that. Service manual has you release each clip, then slide the trim piece forward or backwards (depending on the side) - the part is inexpensive, so when mine gets ugly enough that I want to fix it, I'll probably just order up a replacement for each side (MSRP on the parts is $35/side plus about the same in plastic fittings) - below are the instructions on removal from the service manual. Link to comment Share on other sites More sharing options...
