fame4dame268 Posted May 10, 2018 Share Posted May 10, 2018 Hey guys am trying to resolve a fault code here which is "Er Pd" I know it has to do with the power windows. I had to change the main power window console cause the original was faulty, now it has been replace the driver side window still won't work, any help would be appreciated Sent from my SM-G955F using Tapatalk Link to comment Share on other sites More sharing options...
08SpecB_DE Posted May 11, 2018 Share Posted May 11, 2018 You need to figure out what's wrong with that window. When you say main power window console.....? Master switch? Link to comment Share on other sites More sharing options...
fame4dame268 Posted May 11, 2018 Author Share Posted May 11, 2018 You need to figure out what's wrong with that window. When you say main power window console.....? Master switch?Master switch, yes that it is Sent from my DIGICEL DL910 using Tapatalk Link to comment Share on other sites More sharing options...
08SpecB_DE Posted May 12, 2018 Share Posted May 12, 2018 Check the motor in the LF window. Make sure you have power and ground at the motor. Try jumping the motor to see if it will start working. Link to comment Share on other sites More sharing options...
